so i noticed while mowing, when i steer to the right i have a wider steer radius then steering to the left. is there any way i can adjust it?
steering to the left more.
Started by
Guest_jdecker94_*
, Jul 15, 2011 08:47 PM
9 replies to this topic
#1
Guest_jdecker94_*
Posted July 15, 2011 - 08:47 PM
#2
OFFLINE
Posted July 15, 2011 - 09:13 PM
Every cub I've ever had steered tighter to the left. Its kinda the nature of the beast I think. I personally think it was built into them so that they turn tighter on the side of the deck you would trim with. If you want to try and make it turn tighter to the right you could center the wheel between stops and then see where your fron wheels are in relation to this. If they seem to be more to the left take the steering arm off at the steering box, center up the front tires so they are straight ahead and then adjust the steering arm ball joints accordingly till the steering arm lines up again with the steering box centered.
- KennyP said thank you
#3
Guest_jdecker94_*
Posted July 15, 2011 - 09:33 PM
alright, will do.
#4
OFFLINE
Posted July 16, 2011 - 04:10 AM
I had to do that on another tractor as the wheel wasn't centered when I was going straight.
#5
Guest_jdecker94_*
Posted July 16, 2011 - 11:03 AM
i popped the tierod off and adjusted it a bit. seems better now.
#6
OFFLINE
Posted July 16, 2011 - 11:27 AM
Maybe they are built for NASCAR use also.
#7
Guest_jdecker94_*
Posted July 16, 2011 - 11:32 AM
actually the tight left steering helps when i pull the grader. and yes a 12 horse cub pulls the grader just fine. but its funner with the bolens lol.
#8
ONLINE
Posted July 16, 2011 - 03:31 PM
There you go!Maybe they are built for NASCAR use also.
#9
OFFLINE
Posted July 16, 2011 - 03:54 PM
Doing this to my Cub 127. how to make you old cub cadet steer sharper, cub cadet 122 - YouTube
My yard is 3/4 of an acre so you can see why I need a slightly sharper turning radius.
I'm also looking for narrow 8x4 rims.The ones on my cub are the wider ones with the 7 rib balloon tires that like to slide all over the place in wet or snowy conditions.
#10
ONLINE
Posted July 20, 2011 - 12:14 PM
To make your Cub steer the same in both directions, remove both ends of the tie rod and both ends of the drag link. Straighten both front tires to where they are pointing dead straight ahead. Adjust your tie rod ends until they are center 90 degrees into each spindle arm. Be sure the tie rods ends are 90 degrees. Now, turn your steering wheel counting the number of turns lock to lock. Center your steering wheel by halving that number to find the center. Adjust each end of the drag link until they can be perfectly 90 degrees each end, one into the steering gear, the other end into the left front spindle arm. Be sure you keep both the steering wheel center and your tires straight. This will center both the steering wheel and your turning radius.
For optimum turning radius you can drill another hole outside of the hole for the drag link on the left front spindle as the video in Eric's post shows. If you do that mod, be sure you go back and redo the process I listed above.
