onan carb rebuild parts
16 replies to this topic
#16 brokenbudget OFFLINE
brokenbudget
  • 19 Thanks
  • 178 posts
Posted July 17, 2011 - 08:59 AM
Also, did you get around the 480 second timer?
:smile1:the only way i found is to keep going back every 480 seconds:smile1: the heater keeps going until the water is simmering. i leave the parts in and restart it when i don't hear it going anymore. it isn't really a pain, but it would be nice to have a look in that cleaner and see if the timer can be bypassed. even a half hour length would be nice.
#17 brokenbudget OFFLINE
brokenbudget
  • 19 Thanks
  • 178 posts
Posted August 13, 2011 - 12:14 PM
well a little update on the case, it runs! it runs! i had to reopen the top of the carb to re-adjust the float a bit to stop the fuel from spitting out the top vent. but thats the only issue i have run into, other than the engine running hot. i need to pull the tins off to make sure there isn't any mouse nests under there before i run it for to long. i've only run it enough to move it out of the way for other projects. but it does sound good other than the 2 different mufflers that need to be replaced....
