Rims for a david bradley
8 replies to this topic
#1 woodman OFFLINE
woodman
  • 2 posts
Posted July 15, 2011 - 10:59 AM
I just got 2 1950 David Bradleys and was thinking about restoring one back to new condition.
The other tractor will be truck driver style with chrom rims and painted black with flames.
the clutch will be chrome with a skull on it.
So my quistion is what rims will fit on a david bradley other than the one that came with it. I want to put costom rims !!!!
#2 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted July 15, 2011 - 11:16 AM
I guess we would need ti know what the bolt pattern is.
#3 caseguy OFFLINE
  • 1,629 Thanks
Posted July 15, 2011 - 12:34 PM
Ducky is right. I don't know the bolt pattern off hand, so you'll have to take some measurements for us to help you. You'll need to measure the center to center distance between adjacent bolt holes (they'll all be the same), include the size of the hub hole in the center, and list the number of lugs that are required also.
#4 woodman OFFLINE
woodman
  • 2 posts
Posted July 15, 2011 - 12:42 PM
thank you
i will measure this weekend and reply Monday
#5 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted July 15, 2011 - 05:06 PM
All David Bradley walk behind tractors (2 wheel) use a 3 bolt pattern that is the same as a 5 bolt wheel with a 5-1/2" bolt circle. Ford wheels with that bolt pattern that fit are 1932 and up model A and coupe (hotrodders favorites) and then half ton ford pickups up through the 1960s I believe. So any wheel with a 5 on 5-1/2" lug pattern AND at least a 4" center hole will fit the David Bradley walk behinds.
  • DanO said thank you
#6 DanO OFFLINE
DanO
    Greasemonkey
  • 155 Thanks
  • 350 posts
Posted July 18, 2011 - 07:47 AM
That's Great detail Info Casey, thanks for sharing, I get guys ask me about this all the time. I knew old Ford & I heard old Dodge Rims will Fit the DB's as well but I just never knew exactly what ones & I have never had the need to try them, allways had the originals.
#7 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted July 18, 2011 - 02:42 PM
Same here. I always have originals but I wanted a custom rim so I bought the late 30s Ford spoke wheels for one of them (still haven't installed them). They are for 6.00-16 tires and I was going to use original Allstate knobby tires on them, and get that old tractor look from the 1930s, when they were going from steel wheels to rubber on the big tractors. I know other rims will fit, but the ones I listed will bolt right on and take a 6.00-16 tire, otherwise you can do your own research if you wish to run low profile tires or wide tires, or whatever. Most will require modifications for the center hole, but Ford seems to use the same 4" hole. Do not get a for wire spoke wheel prior to 1932 (the lugs on the outside of the protrusion). You need the later model spoke wheels that hide the lugs inside or else you won't clear the clicker hubs clamps. Not saying they wont fit, because they will, but they will lock in the hubs, literally (interlock the clamp). Just some advice.
#8 Beto OFFLINE
Beto
  • 3 posts
Posted April 02, 2018 - 01:57 PM
Hi Woodman. Since you are looking for other rims, I am looking for an original rim for my David Bradley. I have one good one, but the second one is rusted beyond repair. Are your rims still good and would you be willing to sell one?
Thanks
Beto
#9 DougT ONLINE
DougT
    Dog Approved
  • 7,119 Thanks
  • 5,082 posts
Posted April 03, 2018 - 09:08 AM
Thanks
Beto
Don't hold your breath on this one. The post is from 2011 and Woodman hasn't been on since July 2011.
  • Beto said thank you
