Wheel horse B82 drive belt help
8 replies to this topic
#1 Rocking416 OFFLINE
Rocking416
  • 76 Thanks
  • 191 posts
Posted July 14, 2011 - 08:00 PM
I got a wheel horse B82 i am fixing for a Friend when he bought it the drive belt was to short so i bought the correct one from the wheel horse deeler anyway 1st gear and 2nd and reverse work fine but it will not go into thrird gear the shifter jumps and almost feels like the belt is to tight maybe bad transmission maybe belt adjustment can anyone link to to a belt scematic any advice would be helpful thank you
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted July 15, 2011 - 01:47 AM
Wish I could help, hopefully one of the WH guys has a belt routing pic.
Good luck.
  • Rocking416 said thank you
#3 GWest OFFLINE
GWest
  • 555 Thanks
  • 507 posts
Posted July 15, 2011 - 05:07 AM
To double check the drive belt is Toro 106518 {HA/4Lx87.12"} for the 1980 model 02-08BP01 and 1981 models 02-08BP02 and 02-08BP03.
Same manual for all but the 1981 operator manual is in the Files of
wheelhorsetractormanuals2_5 : wheelhorsetractormanuals2_5
with the 1st of 5 parts named
Tractor 1981 B C and D-Series OM Part1 #810233R1.pdf
The Peerless transmission in all is the model 601-001. The ipl for it is in the Files of
wheelhorsetractormanuals3_8 : wheelhorsetractormanuals3_8
named
Transmission Peerless Transaxle 601-001 IPL.pdf
Also above the file are some Peerless service manuals.
Sometimes there are specific instructions for replacing the drive belt but can't find any for the B-82.
Garry
#4 MH81 OFFLINE
  • 29,978 Thanks
Posted July 15, 2011 - 06:52 AM
Garry, tried the links and they don't seem to work. I looked at them and they seem like they aren't pointing to a specific document?
#5 KennyP ONLINE
  • 40,856 Thanks
  • 47,081 posts
Posted July 15, 2011 - 07:13 AM
I get 'Document not found' error. Doesn't go to any site.
Checked the other links and they go to a yahoo site. Have to be a member to get to the files.
Edited by KennyP, July 15, 2011 - 07:14 AM.
Added Comment
#6 GWest OFFLINE
GWest
  • 555 Thanks
  • 507 posts
Posted July 15, 2011 - 03:46 PM
Only the wheelhorsetractormanuals2_5 is a link. This site wasn't satisfied with what I typed so came up with this.
The other 2 are just the file names pasted into the message. Turns out one is a link to the file if your are a member of Group2_5 but the second is not even if you are a member of Group3_8. I give up.
Garry
#7 Rocking416 OFFLINE
Rocking416
  • 76 Thanks
  • 191 posts
Posted July 15, 2011 - 07:48 PM
Up date baiscly i think its a internal problem Thank you so much for trying to post those awsome links I think im just going to use 1-2 and R for now at least it will cut how often do you need 3 anyway maybe i can pick up a cheap peerless some place
#8 MH81 OFFLINE
  • 29,978 Thanks
Posted July 15, 2011 - 10:40 PM
Caseguy and I are sitting here, trying to find the parts manual. He has a copy of the owners manual, there is no routing diagram in it.
We did find this on the Toro site, kinda shows a little of the routing.
https://www.shoptoro...elt And Pulleys
#9 Rocking416 OFFLINE
Rocking416
  • 76 Thanks
  • 191 posts
Posted July 16, 2011 - 11:20 AM
Thats good and i hate to sound like i dont appericate it cause i really do but myn has a idler pulley and the clutch idler this is kinda a weird model from what i understand lol Thanks for everyones help tho like i said she works in all gears bur 3 so it still going to make a good lawn mower
