Brinly planter
15 replies to this topic
#1 denm OFFLINE
denm
  • 1 Thanks
  • 18 posts
Posted July 14, 2011 - 05:18 PM
So I just picked up a second Brinly planter and I noticed that the drive wheel on my new one is spoked and my first one has a solid wheel. Would this make them different model numbers, or is it simply a design change over the years?
picture of my first planter after restoring
Here is the one I picked up a couple days ago with the spoked wheel
#2 olcowhand ONLINE
  • 41,205 Thanks
  • 31,433 posts
Posted July 14, 2011 - 05:26 PM
I would bet it's just a cost saving with the newer spoked wheel. If they can carve off a nickel's worth of metal....they will!
#3 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted July 14, 2011 - 05:39 PM
Congrats on the Planter!
I sure would love to find one someday
#4 MH81 OFFLINE
Posted July 15, 2011 - 01:50 AM
Boy, that's in pretty good shape. I agree with Daniel, probably year of manufacture.
There is a manual for an earlier one than yours with a spoked wheel HERE
#5 daytime dave ONLINE
  • 4,845 Thanks
  • 6,545 posts
Posted July 15, 2011 - 02:39 AM
Nice planters there. Nice restoration on the first. Congrats.
#6 KennyP ONLINE
  • 38,415 Thanks
  • 45,945 posts
Posted July 15, 2011 - 04:54 AM
So are you going to make a hitch and have two rows going at the same time? That would be neat.
#7 denm OFFLINE
denm
  • 1 Thanks
  • 18 posts
Posted July 15, 2011 - 06:28 AM
probably restore the second one and leave it on the shelf beside the first on display. Only bought it because it was really good price considering how rare they seem to be. This one even had enough chain to drive the fertilizer hopper and it has the row marker minus one piece that I can replicate and it has the 4 original seed plates
#8 caseguy OFFLINE
  • 1,628 Thanks
Posted July 15, 2011 - 06:42 AM
That's a very nice piece you've got there! Two of them in fact! Congrats on another great find!
#9 KennyP ONLINE
  • 38,415 Thanks
  • 45,945 posts
Posted July 15, 2011 - 06:49 AM
Didn't notice until now you were new here. Welcome to GT Talk. It wouldn't take too much to make a simple double sleeve hitch to connect them (with out modding the planters). Would look neat at a show. Whatever you do, good luck with them.
#10 Lilfarmermike OFFLINE
Lilfarmermike
  • 2 posts
Posted November 15, 2011 - 06:58 PM
While opn the subject of Brinly planters does anyone know how I might get one of the large gears for one? This past season I planted my sweet corn with my planters using a 6 cell plate and it looked like I had sowed it.
#11 plowboy OFFLINE
plowboy
    TRACTOROLOGIST
  • 133 Thanks
  • 229 posts
Posted November 17, 2011 - 08:47 AM
those look cool. iv never used 1 but would love 2 have one just thinkn of the time it wd save!
#12 olcowhand ONLINE
  • 41,205 Thanks
  • 31,433 posts
Posted November 17, 2011 - 12:21 PM
If you can't locate another plate, you could always find or make a larger driven sprocket at the planter unit to slow the rotation of the plate you have. Double the teeth and cut the seeding rate in half.
#13 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted November 17, 2011 - 12:38 PM
Not sure the plate you have, but in the past when i ran into this problem i just got out he black rtv and filled every other other plate hole, then trimmed it down with a razor knife. On cast plates you can easily sand blaster the rtv off if it dont work out. Most seeder unit use a common to find sprocket and it would only be a matter of get one mounted to the correct hub and welding it together. I would look at a farm supply store and see whats on the rack, and go from there. If you managed to have the manual it should tell you the correct tooth sizes that came with the unit, and if it not working out recalulate to sizes to suit you. Keep in mind that you will have to also resize your chain to drive any new parts.
#14 Lilfarmermike OFFLINE
Lilfarmermike
  • 2 posts
Posted November 19, 2011 - 07:08 PM
Thanks for the advice, guys.
#15 1967bolens collector OFFLINE
    Deceased
  • 654 Thanks
  • 1,441 posts
Posted February 02, 2012 - 10:13 PM
could you take pics of the row marker for me? i have the same planter an i want to replicate the row marker. also did they have a lifting mec for the marker or did you just lift it up by hand?
