well my hydro lift is strong.
6 replies to this topic
#1 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 12, 2011 - 11:16 AM
so for some laughs, i hooked my plow frame up to the bolens since theres a small pin hole getting welded in the plow right now. and i felt like playing around. so with the plow frame hooked up i went in front of another tractor in my yard, put the plow frame end under the front axle and it lifted it up no problem. so i guess my lift has plenty of power lol
#2 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted July 12, 2011 - 11:36 AM
Sounds good. Just watch you don't bend the rod.
#3 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 12, 2011 - 11:37 AM
the rods that go to my rck shaft?
#4 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted July 12, 2011 - 01:46 PM
I'm not familiar with that particular lift system, but most of them seem to have at least 1 weak link, shaft, pivot etc. Usually discovered just after someone says "Hey, I wonder if it will do this..."
#5 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 12, 2011 - 01:55 PM
yeah, i might be getting a loader soon. then i might as well just keep extra of every fluid and grease in. now the loader will be fun.
#6 Jason4567 OFFLINE
Jason4567
  • 6 Thanks
  • 38 posts
Posted July 13, 2011 - 07:29 PM
The pushrods that go from the rockshaft to the plow frame can get bent. If you mount the monster 2 stage blower without the lift assist springs, it will bend the rods.
Jason
#7 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 13, 2011 - 07:45 PM
i wish i had the 2 stage blower. id leave my neighbors a mess.
