Got to fix this, John Deere la145, question
9 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,754 Thanks
  • 4,521 posts
Posted June 12, 2018 - 07:54 AM
Deck shuts off while useing , then won’t restart, then it will start , then shuts off. This continues on and on. Any ideas.
Not my tractor. Just fixing for somebody.
Noel
Edited by propane1, June 12, 2018 - 07:56 AM.
  • chieffan said thank you
#2 KennyP ONLINE
  • 41,529 Thanks
  • 47,427 posts
Posted June 12, 2018 - 08:09 AM
Looking at JD Parts, that has a relay in there. It may be kicking out on you.
  • propane1 said thank you
#3 propane1 ONLINE
propane1
  • 9,754 Thanks
  • 4,521 posts
Posted June 12, 2018 - 08:33 AM
10.5 volts in battery. date on battery May 2011. Original battery, I'd say. I guessin the battery is the trouble.
Noel
Edited by propane1, June 12, 2018 - 08:35 AM.
  • KennyP and chieffan have said thanks
#4 KennyP ONLINE
  • 41,529 Thanks
  • 47,427 posts
Posted June 12, 2018 - 08:36 AM
Might want to check the charging system too!
  • propane1 and chieffan have said thanks
#5 propane1 ONLINE
propane1
  • 9,754 Thanks
  • 4,521 posts
Posted June 12, 2018 - 08:49 AM
It was at 25 volts at full speed. I'd say the battery would not take any voltage is why the charge is so high.
Noel
#6 tater195 ONLINE
tater195
  • 2,288 Thanks
  • 1,455 posts
Posted June 12, 2018 - 08:58 AM
I worked on one that would do that (box store cub cadet). Seat switch was jumpered and had a bad connection. Low battery voltage is another issue. The stator should put out enough to keep the PTO engaged
#7 propane1 ONLINE
propane1
  • 9,754 Thanks
  • 4,521 posts
Posted June 12, 2018 - 09:36 AM
Tractor data says,  Charging amps  9. Doesn't seem like much.
Noel
#8 tater195 ONLINE
tater195
  • 2,288 Thanks
  • 1,455 posts
Posted June 12, 2018 - 09:39 AM
I thought 20A was standard for electric PTO?
  • KennyP, propane1 and chieffan have said thanks
#9 propane1 ONLINE
propane1
  • 9,754 Thanks
  • 4,521 posts
Posted June 12, 2018 - 10:53 AM
Put the battery in, charging 13.6 volts at about 1/2 or more throttle. Cut my own grass with it and works fine.
Noel
  • KennyP, tater195 and chieffan have said thanks
#10 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,149 Thanks
  • 6,490 posts
Posted June 13, 2018 - 03:26 PM
A friend of mine had the exact same problem with a box store deere a few years ago. New battery solved it.
Sent from my SM-G965U using Tapatalk
