12 year old pc
17 replies to this topic
#1 MFDAC OFFLINE
MFDAC
  • 3,633 Thanks
  • 1,730 posts
Posted June 09, 2018 - 09:53 PM
Well I've bragged up my old PC working flawless all these years an not having any glitches after I went with firefox on Kenny and Alan's advice several years ago. 3 weeks ago it was still working great but I unplugged it as we were out of town for 18 days. When we got back, it gave me fits getting online. The second day it started working great again, and for 9 days it worked perfectly until last night. It booted me off the 'net and refuses to go back on it. I tried a bunch of silly stuff like reboots and turning off firewalls temporarily but nothing helped. Everything else works great as far as photo work, Itunes and other non- internet related chores I use it for.
All I'm saying here it bare with me as far as replying and posting here. I've got an old but nice laptop I'm using here and it is so dang uncomfortable to use that I may not be typing much! When I get a regular keyboard again on something it will be easier to be more active here.
DAC
Edited by MFDAC, June 09, 2018 - 09:55 PM.
  • 101 senior, KennyP, WNYTractorTinkerer and 4 others have said thanks
#2 Trav1s ONLINE
Trav1s
  • 3,642 Thanks
  • 4,597 posts
Posted June 10, 2018 - 07:35 AM
Life on borrowed time always has potential problems.  Is that running Windows7?
  • MFDAC and chieffan have said thanks
#3 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted June 10, 2018 - 07:43 AM
Also, what internet provider do you have?
#4 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,504 Thanks
  • 6,161 posts
Posted June 10, 2018 - 07:59 AM
Puters!!
How long since you cleaned the dust out of it?  unplug it and take the mainframe into the shop, remove the cover and blast all of the dust/dirt out of it..  Be careful of the fans as they will break if you blast air on them..  (how do I know that?)  re install the cover and hook it back up..  Has worked many times on my work and personal machines..  Good Luck..
#5 SimplyRad OFFLINE
SimplyRad
  • 1,368 Thanks
  • 980 posts
Posted June 10, 2018 - 10:51 AM
My wife has an HP and if we turn the power off to it we cannot get online without resetting the date/time on it. Check the date/time to see if it is correct. I paid an IT specialist to tell me that once. Makes you feel just a little bit stupid.
Edited by SimplyRad, June 10, 2018 - 10:53 AM.
#6 secondtry ONLINE
secondtry
  • 2,233 Thanks
  • 1,578 posts
Posted June 10, 2018 - 11:43 AM
Check the connection ports on your laptop. With a little research you may be able to use it as a "tower" just plug in your external key board and monitor. to the laptop. Don
#7 chieffan OFFLINE
  • 11,760 Thanks
  • 7,276 posts
Posted June 10, 2018 - 01:38 PM
Puters!!
Be careful doing that blasting.  15 to 20 PSI is plenty.  90 to 120 as most compressors are set at can break boards, etc.
  • MFDAC said thank you
#8 MFDAC OFFLINE
MFDAC
  • 3,633 Thanks
  • 1,730 posts
Posted June 10, 2018 - 01:45 PM
No it is so old it was running XP. That could be what happened. The internet powers that be may have cut the cord so to speak.
Our provider is Mid-Continent communications.
Puters!!
It was winter of 2016-2017. I had to install a new CD burner in it and I cleaned it then. I will do it again.
I'll check that! This is a dual core HP Pavillion.
I should be able to plug a keyboard into a usb port but the monitor plug won't work. Keyboard is my biggest problem though.
Thanks for the comments and advice! I'll try to tinker with it some more later today.
DAC
Edited by MFDAC, June 10, 2018 - 01:47 PM.
#9 MFDAC OFFLINE
MFDAC
  • 3,633 Thanks
  • 1,730 posts
Posted June 10, 2018 - 01:46 PM
Ok I'll turn down the regulator!
DAC
#10 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted June 10, 2018 - 03:53 PM
That's the battery inside, needs replaced as it provides power to keep that current!
#11 Dee ONLINE
Dee
  • 99 Thanks
  • 86 posts
Posted June 10, 2018 - 04:11 PM
DAC
Check your modem.
#12 MiCarl ONLINE
MiCarl
  • 2,219 Thanks
  • 1,129 posts
Posted June 10, 2018 - 06:13 PM
You're not going to get a current firefox for XP.  I switched my old computers to Linux Lite so I can get current browsers.  Love it.
When Microsoft abandons Windows 7 the last ones will go to Linux too.
Edited by MiCarl, June 10, 2018 - 06:14 PM.
  • KennyP and MFDAC have said thanks
#13 MFDAC OFFLINE
MFDAC
  • 3,633 Thanks
  • 1,730 posts
Posted June 10, 2018 - 08:45 PM
All is well with the date and time on the old HP, it's working good long as I don't try the internet!
Check your modem.
It can't be the modem as I'm using the same internet wire from the old HP in this laptop, and all internet in the house is good!
You're right about current firefox support with XP, but info I found says that version3 XP will work on firefox as long as it is 64 bit. My version is 3 and my pc is a dual core 64 bit. 64 X 2 it claims.
I have a more usable keyboard in place now and found out the monitor that is on my 18 year old pc that powers my sign vinyl cutter works on this laptop! It's a much newer samsung flat panel monitor. The plan may be now to do Secondtry's idea of using this old laptop for the "tower". I'm going to check into installing my sign cutting programs on the 12 year old pc, but I have to see if it has a port I can use for the cutter on the back. I haven't had time to disconnect it and clean it out yet.
So far so good I guess!
DAC
Edited by MFDAC, June 10, 2018 - 08:46 PM.
#14 MFDAC OFFLINE
MFDAC
  • 3,633 Thanks
  • 1,730 posts
Posted June 10, 2018 - 08:50 PM
Oh, I forgot to say, that I can't even get on the net enough to try switching to Linux. I think internet explorer still has to be able to go online to make a browser change? That don't work either.
DAC
#15 OldBuzzard ONLINE
OldBuzzard
  • 7,107 Thanks
  • 4,820 posts
Posted June 11, 2018 - 09:15 AM
It sounds like your NIC (Network Interface Controller) has bit the dust.
I'm guessing that it is on your motherboard, but not to worry.
You can get an addon NIC, install in and the drivers, and you should be good to go.
Here is a place to get one:
https://www.newegg.c...58104 600016289
Out of those, I'd recommend this one:
https://www.newegg.c...=9SIA4A06ME2958
Edited by OldBuzzard, June 11, 2018 - 09:19 AM.
