1977 990 Project
76 replies to this topic
#16 Bolens 1000 ONLINE
  • 15,427 Thanks
  • 18,282 posts
Posted March 05, 2010 - 06:18 AM
Great job so far!. I cant Believe I missed this Thread.
I will definietly have to keep checking back to watch the progress.:bounce:
Awesome!!:worshippy2:
#17 JimRhino OFFLINE
JimRhino
  • 1 Thanks
  • 37 posts
Posted March 12, 2010 - 11:09 AM
Chuck, this is quite an awesome job! I'm looking forward to seeing the 'destruction' this weekend! Good Job!
#18 mjodrey OFFLINE
Posted March 29, 2010 - 11:34 AM
Your doing a great job Chuck.
#19 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted April 06, 2010 - 10:05 AM
Haven't done much lately. Been fighting the rocker shaft and am going to have to give up. Going to have to fix where I mushroomed out the end of the shaft. Hopefuly will finish degreasing the frame this week/weekend then get it wire burshed and primed.
  • Sawdust said thank you
#20 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted April 06, 2010 - 10:06 AM
not giving up on the project just on removing the rocker shaft.
#21 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted April 06, 2010 - 07:34 PM
Hi Chuck good job, they can aggravating at time's can't they. Tell me the front grill what is it made of, aluminum?
#22 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted April 07, 2010 - 07:28 AM
Yes it's Cast Aluminum
#23 jhn9840 OFFLINE
jhn9840
  • 468 Thanks
  • 401 posts
Posted April 17, 2010 - 07:40 AM
Good work on the project Chuck. Love frame up restorations. Only thing better than watching it come apart is watching it go back together.
jhn9840
John
#24 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted April 19, 2010 - 06:40 PM
jhn9840
John
I am right there with ya John, I love watching them get torn down and put back together. The finished product is the greatest reward though.
Have ya worked on the 990 much lately Chuck with working on the garden and everything?
#25 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted April 20, 2010 - 07:11 AM
I have done a little wire brushing, but have been busy trying to do lawn work and everything else. Hopefully soon I will get some shop time.
#26 Shawn OFFLINE
Shawn
  • 13 posts
Posted May 06, 2010 - 12:06 PM
Those rocker shafts are a pain. I just finished scrapping out (for parts) an MTD just like that. I wasn't able to save the rocker shaft, I ended up cutting it out.
#27 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted June 15, 2010 - 02:32 PM
Just a update that there is nothing to update. I moved some parts around last weekend. I need to find time to work on it. I think the only open time slot is 12 am to 5 am and that is currently used for sleeping.
#28 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted August 05, 2010 - 07:56 AM
Pulled the head on the 16 hp Briggs. cylinder walls look good, Piston had 020 stamped in the top so i am assuming that it has been rebuilt at least once. Valves look cruddy. This motor smoked more that I would like so that why I was going to rebuild it. I might be able to hone it and just put in new rings. I will try to get picture tonight.
#29 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 05, 2010 - 08:55 AM
Chuck, check the valves & guides for wear also. If they are worn, it'll still smoke even with new rings. Worn valves/guides can make as much smoke as bad rings.
#30 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted August 05, 2010 - 09:03 AM
I was going to look at them since the cylinder looks so good. Went on briggs site and have made a shopping list. will add valve parts to it as well.
edit: I saw I can get a whole cyliner assemebly (top part of block) for 548.75. That cheaper than a repower if it is ever needed.
