Gonna try one of these!
16 replies to this topic
#16 glgrumpy OFFLINE
  • 8,849 Thanks
  • 8,036 posts
Posted June 03, 2018 - 06:11 PM
Powerwashed today, blue layer of failing paint off! Now can see all the parts. Found engine ID on Clean shrould, was as mentioned above.
  • bprzyw, propane1, logmillingman and 1 other said thanks
#17 glgrumpy OFFLINE
  • 8,849 Thanks
  • 8,036 posts
Posted June 13, 2018 - 08:21 PM
Update:  Finally got carb cleaned and a few parts bought to get back together. No kit for this thing, had to get some things seperate, a little diff.  Mounted it today, got gas tank mounts cleaned and tank back on. I still have to jump selinoid yet before can crank, key not functional yet. Darn thing cranked a bit and took off. A little fast, but held throttle back. The throttle and choke controls need to be be freshened up, kinda sticking. I played with it some by hand control, will work on other stuff later. SO, now at least will start and run. Once I get controls all working right, most are stuck, should be able to see if drives. Doing many tractors and projects at once, not sure when get back to this one.
  • KennyP, bprzyw and logmillingman have said thanks
