MF12 with trouble some 12hp Tecumseh
24 replies to this topic
#16 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted July 23, 2011 - 06:09 AM
I checked the height of the pins, and they were right. The Ignitions units are the same and are also mounted identical. I gaped the unit to .008 It starts up great and idles fine, but once you bring up the rpm's it seems to run rough.
#17 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted July 23, 2011 - 06:59 AM
Sounds like the front pin isn't doing it's job? Anyone else?
From what I understand, the front pin is shorter so it won't trigger until the engine is running. This advances the engine 17 degrees.
I will try to look into this in my manual tonight. Gotta work today.
#18 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted July 23, 2011 - 07:32 AM
You are right. the Tall pin is for start up, and after a certain rpm the shorter pin takes over and advances the timing. This was my thought but was thinking it could still be the Ignition unit.
#19 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted July 24, 2011 - 12:21 PM
I contacted Ed Stoller, and he suggested using a timing light to see if the SSI is switching pins after start up. Im going to try this tonight or tomorrow
#20 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted July 24, 2011 - 07:56 PM
Looked at the manual today. The only pin adjustment was to remove the flywheel & drive the pins in or out.
The shorter pin is to be .187" and the longer pin .250
The gap from the long pin to the pickup was listed as 5-10 thou( you're already at 8)
#21 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted July 24, 2011 - 09:35 PM
I just ran the engine with a test light and the SSI is running off the correct pin, but it does have a consistent misfire. I will check the spark plug before I buy anything more for this engine.
BTW, I contacted overnight solutions and the replacemant coil is currently available
Edited by bread320i, July 24, 2011 - 09:41 PM.
  • mikebramel said thank you
#22 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted August 02, 2011 - 09:57 PM
The Massey 12 was running pretty good last night. I spent some time cleaning the carb, and adjusting it. It was still running rough, but I kept running it around the yard and it seemed to clear up. So I'll try again and see how its running them
#23 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted August 02, 2011 - 10:06 PM
Your engine might benefit from lapping the valves and cleaning the carbon out of the combustion chamber.
Sounds like your getting working better.
Edited by DH1, August 02, 2011 - 10:24 PM.
added content
#24 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted August 02, 2011 - 10:20 PM
Glad to hear it's getting better. Are you getting much blow by? I'm wondering if you had sluggish or sticky rings.
#25 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted August 03, 2011 - 09:09 PM
I did remove the head the clean all the carbon. I didnt lap any valves. The engine ran really good when I got it so I didnt think it needed much.
