Introducing myself
17 replies to this topic
#1 flip OFFLINE
flip
  • 1 Thanks
  • 38 posts
Posted July 09, 2011 - 07:19 AM
Hi there;
I just joined after picking up a 316 Onan. It was repainted, and the painter seemed to have no regard for preserving serial numbers. I have never seen a machine so devoid of identifying information.
Are there an hidden locations that an identifying mark could be found. I am not even sure which engine I have.
Flip
#2 Bolens 1000 ONLINE
  • 15,426 Thanks
  • 18,282 posts
Posted July 09, 2011 - 07:34 AM
Welcome to the Forum!
If you can get some pictures posted of the engine that may help with identification.
#3 caseguy OFFLINE
  • 1,629 Thanks
Posted July 09, 2011 - 07:38 AM
:wave: flip Welcome to GTTalk! It's great to have you here! Hope that you can find the help that you need.
#4 Alc OFFLINE
  • 7,227 Thanks
  • 7,579 posts
Posted July 09, 2011 - 07:41 AM
Welcome to GTtalk flip , I'm sure someone will be able to help you out , Al
#5 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted July 09, 2011 - 08:45 AM
Hi there;
Flip
Hello and welcome
The 316 Onan was originally equipped with a B series 16 hp Onan. Production began in 1984. Then in 1987 the 316 was powered with a P series 18 hp Onan. I am unsure if they ever used a P series 16 hp .... my guess is they did not. There are ways to identify whether you have a P or B .... the air cleaner is different. I am sure they explain over at smallenginewarehouse.com how to distinguish between B and P series....
#6 MH81 OFFLINE
  • 29,978 Thanks
Posted July 09, 2011 - 10:20 AM
Thanks for joining up & :welcome: to GTTalk.
Looks like you are already getting the information you need. Thanks Guys.
#7 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted July 09, 2011 - 10:43 AM
Well .... up until 1983 JD had riveted- on engraved metal serial / model no. tags .... but then replaced with a stick on paper label. And prior to 1983 used all kohler Engines mostly and at least you have the model number cast into the block near the output shaft.
#8 mjodrey OFFLINE
Posted July 09, 2011 - 10:44 AM
Flip,welcome to the forum,glad to have you with us.
#9 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 09, 2011 - 01:41 PM
Welcome flip. There should be a riveted plate on the console near the ignition switch. I think that is the only place there is a chassis serial no. on them.
#10 flip OFFLINE
flip
  • 1 Thanks
  • 38 posts
Posted July 09, 2011 - 06:11 PM
I think I figured out the motor. It has the oil filter coming through the air baffle. That should mean it is the B43E, making this an early 80s 16 horse.
#11 flip OFFLINE
flip
  • 1 Thanks
  • 38 posts
Posted July 10, 2011 - 06:14 AM
Hello and welcome
Thanks; That pretty much confirms I was right. So it is '84 - 86' with a P series 16 hp.
This thing has a lot og guts for 16 hp.
#12 KennyP ONLINE
  • 40,906 Thanks
  • 47,104 posts
Posted July 10, 2011 - 06:22 AM
:welcometogttalk: Flip. I have one of those engines on a Sears GTV/16. They do have plenty of power.
#13 daytime dave OFFLINE
  • 4,967 Thanks
  • 6,598 posts
Posted July 10, 2011 - 12:25 PM
Welcome flip. Glad you are here.
#14 dstaggs OFFLINE
dstaggs
    In Remembrance, RIP Dale
  • RIP
  • 554 Thanks
  • 1,781 posts
Posted July 10, 2011 - 02:15 PM
Welcome to GTtalk
#15 Meangreen OFFLINE
Meangreen
  • 94 Thanks
  • 300 posts
Posted July 10, 2011 - 02:25 PM
:welcometogttalk:
Those Onan's are power-houses, lots of "grunt"....
