HT23 Re-power
53 replies to this topic
#16 Clevis OFFLINE
Clevis
  • 524 Thanks
  • 234 posts
Posted April 25, 2018 - 05:40 PM
Clevis,
   This is the harness I am being told by Kohler to use: PN# 5475502S
Who knows......I'm lost now. GL Following.........
Bernie
I saw a picture of that harness PN5475502S - that doesn't look like the one I need.  Could you post a pic of the wires coming off of your Kohler?
  • bprzyw and logmillingman have said thanks
#17 bprzyw OFFLINE
bprzyw
  • 222 Thanks
  • 240 posts
Posted April 26, 2018 - 10:26 AM
Clevis,
  Yep, looked at a bunch of harnesses they said I need.......Nothing seems to be right except the ones we already have, 6617618S.
Here are pics of my engine side and key switch side. Engine side hooked up as per pic in Steevo's pic you sent.
Ty
Bernie
  • logmillingman and Clevis have said thanks
#18 bprzyw OFFLINE
bprzyw
  • 222 Thanks
  • 240 posts
Posted April 27, 2018 - 07:24 AM
Clevis,
  Found a pic of Steevo's key switch side. Looks like he has a wire harness on the key switch then to another wire harness....Hmmmm
  • logmillingman said thank you
#19 bprzyw OFFLINE
bprzyw
  • 222 Thanks
  • 240 posts
Posted April 27, 2018 - 08:37 AM
Also  my engine does not have this box:
#20 imac2017 OFFLINE
imac2017
  • 56 Thanks
  • 27 posts
Posted April 28, 2018 - 11:23 PM
Thats going to be a very nice working tractor for the green paint take something the correct color to a automotive paint supply house and have it color matched to a single stage paint then loaded into a couple rattle cans should only cost about $20.00 a can will be a perfect match and any unused paint can sit on a shelf until you need to do more touchup
I went to Serwin Williams and got an match for the green paint.  if anyone needs the information I can post the info of the label.  It was about $25 for a quart which is a lot compared to what you get in a rattle can.  Chris
  • bprzyw, logmillingman and Clevis have said thanks
#21 logmillingman ONLINE
logmillingman
  • 995 Thanks
  • 467 posts
Posted April 29, 2018 - 12:23 PM
Yes thank you, would like the paint and formula for duplication if you could.
  • bprzyw, Clevis and kjmweld have said thanks
#22 Clevis OFFLINE
Clevis
  • 524 Thanks
  • 234 posts
Posted April 29, 2018 - 12:44 PM
Yes. Post it please.
#23 Clevis OFFLINE
Clevis
  • 524 Thanks
  • 234 posts
Posted April 29, 2018 - 02:17 PM
I went to Serwin Williams and got an match for the green paint. Chris
Chris,
In the pinned color thread someone posted the HT23 green from Sherwin Williams. Is the code different from what they made for you?
LINK:
http://gardentractor...des#entry658198
Edited by Clevis, April 29, 2018 - 02:19 PM.
  • bprzyw and imac2017 have said thanks
#24 Clevis OFFLINE
Clevis
  • 524 Thanks
  • 234 posts
Posted April 30, 2018 - 05:14 PM
IT'S ALIVE!
I spent some more time on it this weekend.  After studying the wiring diagram for the newer Kohler, I realized the old Kohler K switch wasn't going to work and I needed a new one (5pt + ground).  I ordered that switch plus some new throttle/ choke cables and got them in time for the weekend.  I changed the oil, put in new plugs and air filter.  After putting in the new fuel line, I couldn't wait to fire it up.  I plugged in the wiring harness and the switch.  It turned over, but it wasn't pulling any fuel.  I took the line and tank off again and found the fuel petcock on the bottom of the tank was plugged with a rusty sludge.  I had rinsed the tank several times with fresh gas but didn't think to check the valve.  I brushed it out and ran some carb cleaner through it.  This time it started pulling fuel and within a few seconds it fired up.
After it ran - I just had to throw on the hood and fender and ride it around a bit.  This is my first Eaton 2 sp hydro.  In high, this tractor jumps into action.  I have loved my HT20, but between the softer spring seat, 2 speed hydro and better fuel economy of the newer Kohler - I may have a new go to.
I still have several things I need to do - finish the wiring (lights, ammeter and hour meter), prep and paint the dash tower and put in a new set of PTO belts (I found I have an off sized belt not pulling its weight.)  My daughter also informed me that the decals weren't cutting it - so I've got decals on order too.
I've attached some pics and here are some videos of the new Kohler starting and my daughter and son having fun on it.
Edited by Clevis, April 30, 2018 - 05:31 PM.
  • Rock farmer, Austen, nglauer and 5 others have said thanks
#25 pryan05 ONLINE
pryan05
    LGT
  • 688 Thanks
  • 376 posts
Posted April 30, 2018 - 05:35 PM
Nice work!  That will work very well for you ;)
  • bprzyw, logmillingman, Mark 149 J. and 2 others have said thanks
#26 logmillingman ONLINE
logmillingman
  • 995 Thanks
  • 467 posts
Posted April 30, 2018 - 08:12 PM
That Kohler looks real nice in that HT23, great job!
  • Austen, bprzyw, Mark 149 J. and 2 others have said thanks
#27 Austen OFFLINE
Austen
  • 1,837 Thanks
  • 967 posts
Posted April 30, 2018 - 08:59 PM
Yeah, buddy!!! Now that should make you feel proud!! Nice work my friend, five stars all the way!!! Nice and clean and professional, stock exhaust and everything. Love it. Way to go! Wohooo! :thumbs: :thumbs: :thumbs: :thumbs:
Edited by Austen, April 30, 2018 - 09:01 PM.
  • bprzyw, logmillingman, Mark 149 J. and 3 others have said thanks
#28 kjmweld ONLINE
kjmweld
  • 634 Thanks
  • 399 posts
Posted April 30, 2018 - 09:29 PM
Agreed, nice clean repower. Nice to see your attention to detail. Congrats on a nice operable tractor again. 👍
  • Austen, bprzyw, logmillingman and 2 others have said thanks
#29 fonz3482 OFFLINE
fonz3482
  • 1,456 Thanks
  • 809 posts
Posted May 01, 2018 - 04:25 AM
Awesome! Sounds great and seems to work flawlessly!
#30 bprzyw OFFLINE
bprzyw
  • 222 Thanks
  • 240 posts
Posted May 01, 2018 - 12:05 PM
Clevis,
   Sounds awesome!!!! You must be grinning ear to ear. Nice job!!! :rocker2: Both tractors are great! Glad you got it running. I just ordered a new switch, and am digging for my spare starter since I think the one on the engine is toast.
Good Luck! :thumbs:
  • Austen, logmillingman, Mark 149 J. and 2 others have said thanks
