MTD front axle assembly
Tags
wanted
457 views 2 replies 2 participants last post by  wku88
#1 ·
Hey guys, if you would be so kind as to check your junk/scrap/parts machines I would appreciate it. In particular, I need a front axle assembly for my MTD 1846. This is the model with 16x6.50-8 front tires. The spindles are longer on this version. The smaller wheel version will not work. Bonus if you can tell me if the cast iron axle from late model Cub Cadet will swap in. Just to refresh your memories, this is the type that has a 2" flanged hole for the axle pivot, and is clamped between two plates. The late CC cast axle appears to have a machined boss that looks like it will fit in the stamped steel holes on the mounting plate.
Please let me know what you have!
#3 ·
