MTD 12-760
4 replies to this topic
#1 Mrzee OFFLINE
Mrzee
  • 1 Thanks
  • 6 posts
Posted April 17, 2018 - 12:41 AM
Info needed on what the electrical contact under the forward and reverse gear selector plate is for ??
#2 KennyP ONLINE
  • 40,082 Thanks
  • 46,745 posts
Posted April 17, 2018 - 04:03 AM
I would guess Neutral.
#3 jms180 ONLINE
jms180
  • 1,621 Thanks
  • 1,621 posts
Posted April 17, 2018 - 07:09 AM
i agree neutral for start
#4 boyscout862 ONLINE
  • 13,432 Thanks
  • 9,381 posts
Posted April 17, 2018 - 07:37 AM
The switch is probably a "neutral safety switch". This prevents the engine from being started in gear. The engine can only be started in neutral. You probably need to disconnect it from its wires and test it with an ohm meter or a continuity tester. Good Luck, Rick
#5 Mrzee OFFLINE
Mrzee
  • 1 Thanks
  • 6 posts
Posted April 17, 2018 - 03:17 PM
thanks guys. will check it out
