New tires for the 318
10 replies to this topic
#1 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted April 16, 2018 - 10:20 PM
Ordered the Vredestein V61's for the JD 318 today. They are suppose to arrive Friday if all goes well. Just in time for my B-day.
I guess I better get going on painting the rims.
  • EricFromPa, KennyP, CRFarnsworth and 5 others have said thanks
#2 Trav1s ONLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted April 17, 2018 - 10:21 AM
I am curious to hear what you think of them.
  • Cjet69 and Mark 149 J. have said thanks
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,108 posts
Posted April 17, 2018 - 06:46 PM
Have fun mounting those, they will resist your efforts to give them a home on a rim.
  • KennyP, Sawdust, Cjet69 and 1 other said thanks
#4 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted April 18, 2018 - 06:13 PM
Pulled the wheels off the 318 and demounted the tires. The tires came off the rims really easy. Found some snot in there, but the inside looks good after a rinse. Popped the rim in my E-tank to strip it and get ready for paint.
  • Mark 149 J. said thank you
#5 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted April 19, 2018 - 12:37 PM
Pulled the first wheel out of the E-tank and hosed it off. Followed that with the blast cabinet. Need to finish up straightening around the rim edge in a few spots and then I will hit them with OSPHO.
  • Sawdust and Mark 149 J. have said thanks
#6 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,689 Thanks
  • 1,509 posts
Posted April 19, 2018 - 02:42 PM
They look to be in good shape!
Do you have pictures of how your e tank is set up?
  • Cjet69 said thank you
#7 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted April 19, 2018 - 03:19 PM
The tank is approx. 250-275 gallons with the top cut out. Once its filled we add the sodium carbonate that we buy at a pool supply outfit. We use our regular battery charger on the 10 amp setting. This tank is big enough to put our 38" tractor rims in it.
  • Alc, KennyP, Mark 149 J. and 1 other said thanks
#8 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,689 Thanks
  • 1,509 posts
Posted April 19, 2018 - 04:21 PM
Thanks for show me what you used!  I was thinking of using the same type of tank!
#9 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted Yesterday, 01:33 PM
Cleaned up the second wheel today.
#10 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted Yesterday, 05:54 PM
I finished straightening the bead lip. Then touched it up with a small grinding disc in my Die grinder and applied OSPHO.
#11 Cjet69 ONLINE
Cjet69
  • 613 Thanks
  • 335 posts
Posted Today, 12:46 AM
Shot a short vid of the tire demounting using our slide hammer bead breaker.
