MTD Wizard 50 inch deck
4 replies to this topic
#1 tom tractor ONLINE
tom tractor
  • 253 Thanks
  • 238 posts
Posted April 16, 2018 - 02:45 PM
How is the cut on the 50 inch decks for the MTD Wizard?  Does it cut nicely.  Is the deck oversized for the 16hp?
#2 VTXrider ONLINE
VTXrider
  • 529 Thanks
  • 384 posts
Posted April 16, 2018 - 07:14 PM
I use mine to cut the back yard/field and it can bog down in heavy grass. As long as the blades are sharp, the engine will stay at top revs at average travel speed. Without anti scalp wheels, it does damage to uneven areas and the slide bars on each side sometimes dig in during a turn. The striping roller is next to useless because it bends easily and stops rolling.
To get a better cut, I removed the roller and put 5" caster wheels on the adjustable height brackets.
  • olcowhand, Alc and tom tractor have said thanks
#3 glgrumpy OFFLINE
  • 8,719 Thanks
  • 7,973 posts
Posted April 16, 2018 - 08:25 PM
Hey! Maybe I should do that to mine???  I just posted on missing adjusters, now seeing this. Hmmmm!  Have any closer shots or when making them that I can see better on how mounted??  Might have to change my process!
  • tom tractor said thank you
#4 VTXrider ONLINE
VTXrider
  • 529 Thanks
  • 384 posts
Posted April 17, 2018 - 11:37 AM
Closeups of the welded on bracket and wheel. I had access to free 5" caster wheels and bolts. 6" X 2" would be even better I think. You can see the bottom of the bracket is dragging. Check for clearance with the deck and tractor tires when making this mod. My chains come close when traveling with the deck raised. Make sure the wheel does not rub on the deck at all adjustment heights.
I have an extra set of wheels when these wear out.
Edited by VTXrider, April 17, 2018 - 11:43 AM.
#5 glgrumpy OFFLINE
  • 8,719 Thanks
  • 7,973 posts
Posted April 18, 2018 - 07:34 PM
Cool!  Thanks for the great pictures!  This looks like much quicker route than the rollers building.
  • VTXrider said thank you
