so with the newly acquired cub. when i turn the key to the start position. nothing happens you just hear a knock. just 1 knock. anyone have an idea of what it is? it sounds like it coming from the dash or under it.
knock when i try to turn it.
Started by
Guest_jdecker94_*
, Jul 08, 2011 09:35 AM
4 replies to this topic
#1
Guest_jdecker94_*
Posted July 08, 2011 - 09:35 AM
#2
OFFLINE
Posted July 08, 2011 - 10:56 AM
That is the start solenoid engaging, so it IS getting power. If the cable leading from it to the starter is also getting power when engaged, then likely a starter issue. If the power is not making it to that cable, then the solenoid is likely bad.
#3
Guest_jdecker94_*
Posted July 08, 2011 - 11:48 AM
well theres 2 orange wires in my wire harness i can see are cut. any idea where they go to? also how much is a starter?
#4
ONLINE
Posted July 08, 2011 - 11:56 AM
j, Try putting a set of jumper cables on the starter directly to the battery and see if it will turn the motor over. If it does, it's a bad solenoid, if it doesn't, the starter needs rebuilt. You may have a starter, alternator rebuild shop around your area, if so take the starter to them and see what they want to rebuild.
#5
Guest_jdecker94_*
Posted July 08, 2011 - 12:01 PM
the starter was moving last night, slowly, and struggling. can i rebuild it myself? =D i know a kit is 55 bucks, which i would invest since it would increase my turn around.
