NTM 1961 International Cub Lo-Boy
14 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,340 Thanks
  • 2,702 posts
Posted April 14, 2018 - 05:09 PM
Late this winter I decided to hunt up a Cub Lo-Boy, found one on CL a couple hours from home.  Had too many things going on with the surgery & new trailer purchase to go after it right then.  I watched it until I could go after it, surprise, still available!  Made arrangements to look at it a couple weeks ago & brought it home:  Tractors 2018 003.JPG   Tractors 2018 004.JPG
First thing was to take off the 59" Woods belly mower (I have a better mowing tractor), then start ordering needed parts.  Tractors 2018 005.JPG
I have an air cleaner ready to put on now, drawbar is on, seller had taken a cutting torch to the seat frame & welded on an old Ferguson pan seat   :wallbanging:   I repaired the cut up frame & ordered new cushions for it.
Still has issues, but what old tractor doesn't?  An oil leak needs fixed, governor started acting up a couple days ago, needs a fresh paint job, etc.  Gives me something to do, as if I don't have enough projects in the works already!   :D
Took it & PK to a small (very small) show today:  Tractors 2018 018.JPG
  • Alc, KennyP, Lmiller3358 and 9 others have said thanks
#2 CRFarnsworth ONLINE
CRFarnsworth
  • 5,214 Thanks
  • 2,269 posts
Posted April 14, 2018 - 05:33 PM
     :thumbs:  :thumbs:  :thumbs:
I like that style a lot better than the later model yellow and white ones.    Rick
  • grnspot110, KennyP, boyscout862 and 2 others have said thanks
#3 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,602 posts
Posted April 15, 2018 - 10:29 AM
Hi grnspot110, not a bad looking Cub loboy I like that style of Loboy and that grill etc, wonder what the thinking was on the aircleaner, I know many including the "A" & "B" get the seats hacked or replaced, will be following your updates
Was the aircleaner  originally between the grill & radiator like on the early Cubs?
Edited by MNGB, April 15, 2018 - 10:32 AM.
#4 grnspot110 ONLINE
grnspot110
  • 4,340 Thanks
  • 2,702 posts
Posted April 15, 2018 - 11:01 AM
Under the hood, right behind the external intake that's on it now.
You can see the hole in the hood in this picture:  Tractors 2018 015.JPG
  • KennyP, MNGB, Leonard VanCamp and 2 others have said thanks
#5 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,602 posts
Posted April 15, 2018 - 11:49 AM
Thanks I must be thinking of something else my Earthmaster has it between the grill and radiator when I restored it the was no aircleaner to be found so I used a Cub one and it fit perfectly just had to shorten the inlet air tube.
I see you got the seat changed looks good
Edited by MNGB, April 15, 2018 - 11:51 AM.
  • grnspot110 said thank you
#6 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,090 Thanks
  • 591 posts
Posted April 15, 2018 - 01:00 PM
Looks like it’s in real good shape . Nice !
  • grnspot110 and Mark 149 J. have said thanks
#7 grnspot110 ONLINE
grnspot110
  • 4,340 Thanks
  • 2,702 posts
Posted April 19, 2018 - 04:06 PM
Been doing some work on Cubby today, took the "junk yard special" alternator off.  Had to do some cutting where the knot-head welded to one of the bolts that held the regulator plate:  Tractors 2018 019.JPG
New "mini" alternator is on order, I'll make a new bracket for it.
Put on the new exhaust pipe & muffler:  Tractors 2018 021.JPG
Air cleaner is now in place:  Tractors 2018 020.JPG    Tractors 2018 022.JPG
  • Alc, KennyP, Jazz and 2 others have said thanks
#8 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,602 posts
Posted April 19, 2018 - 05:24 PM
Hi I just love that alternator bracket :dancingbanana: looking good now aircleaner exhaust system soon to be alternator,  are you going whit another Delco or are you thinking of the small Hitachi or Denso? Are you sticky with the plumping pipe hanger for the coil mount?
Edited by MNGB, April 19, 2018 - 05:26 PM.
  • grnspot110 and KennyP have said thanks
#9 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted April 19, 2018 - 05:50 PM
This tractor doesn't know yet how good of a home it has now! Great job, Lowell!
#10 grnspot110 ONLINE
grnspot110
  • 4,340 Thanks
  • 2,702 posts
Posted April 19, 2018 - 06:36 PM
Densco.
I haven't had time to look yet, but I think I have a coil bracket.
  • MNGB said thank you
#11 CRFarnsworth ONLINE
CRFarnsworth
  • 5,214 Thanks
  • 2,269 posts
Posted April 19, 2018 - 09:49 PM
   Good looking tractor.  But how's it feel in amongst all that green?
#12 grnspot110 ONLINE
grnspot110
  • 4,340 Thanks
  • 2,702 posts
Posted April 20, 2018 - 05:34 AM
Jinxed!!!      :bigrofl:
  • KennyP and MNGB have said thanks
#13 grnspot110 ONLINE
grnspot110
  • 4,340 Thanks
  • 2,702 posts
Posted June 09, 2018 - 06:08 AM
Slow coming update:  I have finally gotten the hood cleaned up & painted;  Tractors 2018 025.JPG   Tractors 2018 026.JPG   Tractors 2018 027.JPG
Progress has been slow due to normal spring garden work & mowing, along with the problem of a bad knee.  Hope to get Cubby to a show next Saturday if I'm up to it!
  • Alc, KennyP, CRFarnsworth and 3 others have said thanks
#14 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,602 posts
Posted June 09, 2018 - 07:35 AM
Hi grnspot110, that is looking good nice job thanks for posting the update
#15 KennyP OFFLINE
  • 41,448 Thanks
  • 47,379 posts
Posted June 09, 2018 - 07:58 AM
Hope the knee allows you to go! Cub looks good!
