Kubota zb-600c-1 fuel problems
29 replies to this topic
#16 Paradox1559 OFFLINE
Paradox1559
  • 20 Thanks
  • 37 posts
Posted April 15, 2018 - 04:13 PM
Any idea how I can fix that?
#17 olcowhand ONLINE
  • 42,339 Thanks
  • 31,784 posts
Posted April 15, 2018 - 04:45 PM
Not really.  Maybe keep it wet with penetrating fluid, and very light taps, then carefully try wiggling it?
#18 Paradox1559 OFFLINE
Paradox1559
  • 20 Thanks
  • 37 posts
Posted April 15, 2018 - 05:05 PM
Am I even supposed to be able to move it? If so, how far is it supposed to?
#19 olcowhand ONLINE
  • 42,339 Thanks
  • 31,784 posts
Posted April 15, 2018 - 05:09 PM
I really can't give good advice on this without having any knowledge of it's systems.
#20 Paradox1559 OFFLINE
Paradox1559
  • 20 Thanks
  • 37 posts
Posted April 15, 2018 - 05:27 PM
Yeah, I've tried talking in kubota forums specifically. But you would think its all a closely guarded secret.
#21 olcowhand ONLINE
  • 42,339 Thanks
  • 31,784 posts
Posted April 15, 2018 - 06:59 PM
Posting some good pics of the suspect areas might help.
#22 Paradox1559 OFFLINE
Paradox1559
  • 20 Thanks
  • 37 posts
Posted April 15, 2018 - 07:09 PM
Here is the best I could get of the inside of the governor housing.
#23 olcowhand ONLINE
  • 42,339 Thanks
  • 31,784 posts
Posted April 15, 2018 - 07:58 PM
Oh, I see it's similar to the larger diesels.  I'm afraid that lever should move easily, so you must have governor issues which will require getting deeper in.
#24 Cvans OFFLINE
  • 7,067 Thanks
  • 6,285 posts
Posted April 15, 2018 - 10:09 PM
I need to see a photo of outside of the governor. It could be that the speed adjustment screws are not set correctly.
Edited by Cvans, April 15, 2018 - 10:12 PM.
#25 Paradox1559 OFFLINE
Paradox1559
  • 20 Thanks
  • 37 posts
Posted April 16, 2018 - 01:13 AM
It's definitely the fuel rack. It won't budge. I'm going to have to try a little manual stimulation, with some penetrating lube and try and free it up. If that doesn't work, I'm going to need to open it up.
#26 Paradox1559 OFFLINE
Paradox1559
  • 20 Thanks
  • 37 posts
Posted April 16, 2018 - 08:03 PM
PROBLEM SOLVED!! With about 30min and some pb blaster, I managed to gently free up the fuel rack. Now it idles, revs and shuts down. One of the injectors is a little leaky, but other than that it runs good. I turned $20 into way more, and that's a win in my book.
  • olcowhand, KennyP and Cvans have said thanks
#27 olcowhand ONLINE
  • 42,339 Thanks
  • 31,784 posts
Posted April 16, 2018 - 08:06 PM
That is super!  I'll give you $40 for it and double your money!  :smilewink:   Awe heck, I'd go $60 even!  :smilewink:  :smilewink:  :smilewink:  :rolling:
  • KennyP, Cvans and Trav1s have said thanks
#28 Paradox1559 OFFLINE
Paradox1559
  • 20 Thanks
  • 37 posts
Posted April 16, 2018 - 09:48 PM
That's a tempting offer, however I have plans for this motor now. I'm going to build a diesel motorcycle. It should fit in just about any frame with minimal modification.
  • KennyP and Cvans have said thanks
#29 Cvans OFFLINE
  • 7,067 Thanks
  • 6,285 posts
Posted April 16, 2018 - 10:54 PM
 Daniel must be impressed with your work. In all my years here I have never seen him offer that much for anything.   :bigrofl:
Edited by Cvans, April 16, 2018 - 10:55 PM.
  • olcowhand and KennyP have said thanks
#30 olcowhand ONLINE
  • 42,339 Thanks
  • 31,784 posts
Posted April 17, 2018 - 08:42 AM
But it's a diesel!  :D
  • Cvans said thank you
