my new 75$ cub 122 with all the options
  • This topic is locked This topic is locked
21 replies to this topic
#1 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 07, 2011 - 09:32 PM
so i seen a cub on craigslist for 125 bucks. i offered 75 bucks. went and got it, obviously, who wouldnt? it has high low range factor lights hydro lift and it looks like some kind of lift on the back. i tried to start it, the belt was so tight on the starter gen it could barely move. so i figure sometime tomorrow i might get it running. think i got a good deal on her?
#2 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 07, 2011 - 10:01 PM
the starter is really struggling to move it time. tomorrow i might take the belt off and get her moving for a lil bit
#3 MH81 OFFLINE
Posted July 07, 2011 - 11:16 PM
I think you got a great deal, but won't be sure until we see pics.
You may want to roll the engine over without the belt on it just to see if something is binding.
#4 daytime dave OFFLINE
  • 4,935 Thanks
  • 6,579 posts
Posted July 07, 2011 - 11:33 PM
Congrats on a good buy.
#5 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted July 08, 2011 - 04:39 AM
You got a heck of a deal for a 122 and the creeper gear option.
#6 KennyP OFFLINE
  • 40,098 Thanks
  • 46,755 posts
Posted July 08, 2011 - 05:04 AM
Great score. Is the battery charged good? How about grounds, are they clean? Does the motor turn over okay by hand? Try turning starter over without the belt. Starter may need new brushes & bushings. If you have a voltmeter, hook to battery while trying to start. May be a weak cell in battery.
#7 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 08, 2011 - 07:45 AM
the starter without a belt just makes this whining noise and does nothing. thats jumping the starter directly. im sure you all know what i mean. hopefully.
#8 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 08, 2011 - 08:07 AM
i can turn the engine over by hand, but it tough because i got the hydraulic pump hooked up to it too.
#9 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 08, 2011 - 10:26 AM
well i know your all dying for picture so here ya go. also whats the weird knob thing in the center by my hi low selector?:confuse: also where would my light switch be? Photo1 (15).jpg
also is the a mount for a 3 point on the back? or a sleeve hitch? and would the be a dealer option?
#10 olcowhand OFFLINE
  • 42,348 Thanks
  • 31,788 posts
Posted July 08, 2011 - 10:28 AM
That IS the Cub Cadet lift. The IH attachments simply slide into that hole & away you go! You could go to jail for this deal!
#11 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 08, 2011 - 11:01 AM
no way? because i need to sell it to buy this deal bolens with a loader lol.
#12 MF14 plowday special ONLINE
  • 34 Thanks
  • 255 posts
Posted July 08, 2011 - 11:23 AM
:DHeadlights, 3 point, hydraulic system and and under-drive !!! all of the goodies .... he wanted $125 and you offered $75 and got it !
Congratulations ... you win this years biggest chiseler's award !!!
#13 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 08, 2011 - 11:31 AM
lol i almost wanna get it running and use it now lol. theres wires cut on the wire harness. 2 orange wires. i can figure out where they go to. theres wire disconnected. but thats the fun of buying a tractor.
#14 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted July 08, 2011 - 11:33 AM
and this tractor was used as a four wheeler for the last year before it was parked too. the guy thought he had a wheeler when he had a small farm tractor in reality.
#15 EricFromPa OFFLINE
EricFromPa
  • 3,971 Thanks
  • 3,247 posts
Posted July 08, 2011 - 12:13 PM
That's not a knob,it's a Breather for the Hi/Lo Gear box.
Headlight switch should be Up under the dash on the left side of the dash tower when your sitting on the seat.
Well if you part it out,the Hydro Lift pump with cylinder,Headlight panel with switch,Sleeve hitch and Creeper gear will get you around $500 give or take a few bucks.The rest of the tractor with deck should sell for $200-300 if you can make it run.
Edited by EricFromPa, July 08, 2011 - 12:26 PM.
