I got this dang thing dumped in my lap way too long ago, to fix for a friend of mine. No spark, minimal compression...
I have NO service information on this thing. None. I asked here for a manual months ago and Kenny came up with an owners manual and I think a parts manual but neither really details how this dang thing comes apart. Did I say I have never worked on one?
I do have to say THANKS, for what was found and posted here.
I again spent (wasted) another afternoon online, searching for the info I am after. and still came up dry again.
In trying to troubleshoot the no spark situation, I took the flywheel off and discovered everything packed in hardened concrete dust, I cleaned that up best I could, I took off the muffler and found same thing, put that into my glass bead cabinet and it finally came clean,
took alot of time to get it there...
stuck the nozzle of the cabinet gun inside the ports (of the muffler, once I had it off/ NOT the cylinder!!! I ain't that crazy or dumb) and cleaned within the muffler, the best I could......
so I went back to figuring the spark and I discovered that if I spun it with the plug out, and used my Milwaukee 3/8" cordless impact with a hot fresh battery I could get an intermittent spark.... I would up stripping the flywheel nut, had a He11 of a time getting that back off with a Dremel and a small chisel, fortunately the nut sacrificed itself instead of the crank threads...
looked in the exhaust port with a borescope and could see the cylinder wall was badly scored....
I wanted to punt this thing away, until I saw how expensive these saws are//// there are 2 on Epay right now for $350 ish that have definitely seen better days.... I saw an NOS one on there last fall that the seller wanted $1,000 for yikes... I have no idea how old this thing is. but being they are that "salty" I guess it is worth putting some time and money into.
I bought a complete rebuild kit from Epay...crank, rod, piston, cylinder, carb kit, gaskets all in 1 box.... aftermarket, $169 quite a while ago.
I shop at HF EXTREMELY rarely, but I had bought a set of T handle torx specifically for this job..... misplaced them, cannot find them.... so I went back today and bought another set to (try to) finish disassembly of this thing..... got the outer bell off the clutch, there is a sleeve that the needle bearing within that clutch bell (belt pulley) rides on, that will not budge.... that has to come off to get the clutch off so I can split the housing....... don't want to use chanellocks on it or heat... it is obviously a bearing surface for that needle bearing. From what I can see that needle bearing is still available but the sleeve isn't. It is keyed to the crank, by looking at the new crank. HOW DOES THAT COME OFF???? and then how do I get the clutch off? No threads apparently to hold that to the crank....
Has anyone here ever worked on one? Does anyone know where I can find a service/ repair manual ? (prefer paper version, I have no computer or wifi in the garage) I'd be willing to buy a manual.... I'm already way deep into this thing as it is, I just need it done and gone!!!!!!
Edited by dodge trucker, April 07, 2018 - 05:38 PM.
