I am hooking up 2 lights to the rear of my 53 Farmall Super A and wanted to put a Flasher unit in the line...The Only 6 Volt Unit I could get in stock at NAPA was this 3 Prong design...Can anyone tell me how to wire this up correctly??? the Tractor is 6 Volt Positive Ground.
The Flasher Unit is 6 Volt with 3 lettered Prongs : L P X
What goes to what letter???? This darn thing cost $15 and I don't want to fry it.
Need Help With Light Wiring
Started by
DanO
, Jul 07, 2011 04:18 PM
5 replies to this topic
#1
OFFLINE
Posted July 07, 2011 - 04:18 PM
#2
OFFLINE
Posted July 07, 2011 - 05:01 PM
From what I have gathered, and this is just second hand information (sorry, couldn't find a diagram for you) The switched negative from the key switch would go to the "X" terminal, The "L" terminal would go to the light and the "P" terminal will remain unused. The case of the flasher should be grounded (to the + terminal of the battery in your situation, or any good ground on the tractor) This set up would make the lights flash whenever the key switch was in the "on" position. Like I said, this is second hand information, so I would appreciate some backup on this LOL. It is also suggested that a 10 amp fuse be installed in-line. Hope this helps!
- DanO said thank you
#3
OFFLINE
Posted July 07, 2011 - 08:00 PM
As You Can See, Working perfectly Caseguy, thanks so much for the quick reply.
YouTube - Flashing lights
#4
OFFLINE
Posted July 07, 2011 - 08:15 PM
Looks Great DanO, nice job buddy...
#5
OFFLINE
Posted July 07, 2011 - 09:24 PM
Nice work DanO! That should keep you safe! Glad to be of help!
#6
OFFLINE
Posted July 07, 2011 - 09:49 PM
Nice job! And you did a very good job of explaining the installation on the video too.
