My B10 needs rings.
5 replies to this topic
#1 sawdoff OFFLINE
sawdoff
  • 54 Thanks
  • 23 posts
Posted March 26, 2018 - 07:39 PM
My B10 has a 23d Briggs engine. The type is 0129 02. Serial # is 89051. I'm having trouble finding the right ring set for it. The places I have checked recommend  part# 792362 standard but they are too big. This engine has a 3" bore. Has anyone else been down this road before? Any help would be greatly appreciated.
#2 Dayton_King OFFLINE
Dayton_King
  • 1812 Thanks
  • 1287 posts
Posted March 26, 2018 - 08:05 PM
Issue you will find is Briggs no longer supports these engines. That leaves new old stock or Chinese parts. Are you sure it is a 23d. Could they have swap tins. I have a kohler print out for bore sizes but nothing for Briggs. I am a genuine parts mind of guy but if I was you I would reach out to Isavetractors and see what Norman says.
#3 classic OFFLINE
classic
  • 6725 Thanks
  • 2700 posts
Posted March 26, 2018 - 08:21 PM
The 23D with the 0129 spec number is the oddball in the Model 23 series engines. The bore is 3" just like other model 23 engines, but the crankshaft, rod, and piston are unique to the 23D, spec. 0129. Luckily, the ring sets are the same, so just look for Briggs part number 292100 for standard size Briggs model 23 rings. Here are the part numbers for oversize rings.
292101 .010
292102 .020
292103 .030
#4 classic OFFLINE
classic
  • 6725 Thanks
  • 2700 posts
Posted March 26, 2018 - 08:55 PM
Just to let you know, those rings, 792362 supersede part number 299089, and they are for the 243400 series engine, also used in the B10. This engine has a bigger bore and is 24 cubic inches, whereas your 23D is 23 cubic inches. I can see how someone could give you the wrong part number when inquiring about rings for a B10.
#5 EricFromPa OFFLINE
EricFromPa
    Fixer of Broken junk
  • 6773 Thanks
  • 4562 posts
Posted March 27, 2018 - 03:17 PM
Bunch of NOS Briggs 292100 rings on Ebay. That's where I have been getting mine. You can usually get them for $15-$20 shipped.
https://www.ebay.com... 292100&_sop=15
Edited by EricFromPa, March 27, 2018 - 03:17 PM.
#6 sawdoff OFFLINE
sawdoff
  • 54 Thanks
  • 23 posts
Posted March 27, 2018 - 08:55 PM
Ordered some today. $15. Getting the right part can be challenging and expensive. It will be worth it when I hear it fire up again. Thanks for all the great advice and information.
