48 inch Dozer Blade Parts
10 replies to this topic
#1 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted July 07, 2011 - 04:18 AM
Where can I find the trip springs for a Ford 48 inch Dozer Blade (model 09JC9797)?
Any help would be appreciated by this new member to the forum.
Thanks
GEL
#2 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted July 07, 2011 - 05:11 AM
:welcometogttalk: Glad you found us. The part # for these is JAC342350. Some guys are using the Sears trip springs for replacement. A bit cheaper. I have the info somewhere, but can't find it right now. If I do, I'll get it posted for you.
#3 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted July 07, 2011 - 05:13 AM
Welcome to GTtalk , hope you enjoy the site , Al
#4 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted July 07, 2011 - 05:23 AM
Found it!! Sears p/n R9466R from 486.24414 Blade. $7 +/- from Sears. New Holland wants over $50 each for theirs.
#5 caseguy OFFLINE
  • 1,629 Thanks
Posted July 07, 2011 - 05:17 PM
:wave: nycub122 Welcome to GTTalk! Glad to have you here with us! Hope that you find your parts soon! Meanwhile, enjoy the forum!
#6 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted July 08, 2011 - 05:25 AM
KennyP:
Thanks for the info.
Is any modification needed to make these springs work on the Ford Blade?
Thanks to all for the welcome.
GEL
#7 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted July 08, 2011 - 05:29 AM
Not sure if mods are needed. I have to get some for mine. You might have to get a longer bolt, as I don't know the length. I found this over at MTF. Said the worked fine, but no further info. Glad to help where I can.
By the way, Welcome to the forum.
#8 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted October 28, 2011 - 05:21 AM
KennyP:
How did you make out with your springs?
What did you end up using for a bolt?
Just got mine yesterday from Sears and plan on installing today.
Thanks for the help
GEL
#9 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted October 28, 2011 - 05:36 AM
I haven't even gotten any yet, so let us know what, if any, mods are needed. I just picked the info from elsewhere and filed it for future use. Good luck with them. I need to get a set for my blade, just in case I get to use it this winter. Rather doubtful down this way, especially after the heavy snow we got last year. Heck, I've gotten a sunburn the first of Feb. down here.
#10 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted October 29, 2011 - 12:58 PM
Installed the springs today. They came with no thread insert or bolts. I used a 3/8 x 5" grade 8 bolt with a hardened 3/8 flat washer and slid it into the spring, with the bolt head and washer captured inside the spring. Then threaded a 3/8 jamb nut on the bolt all the way to the end of the threads. Inserted the end of the bolt through the hole in the top of the blade and used a 3/8 hardened flat washer, 3/8 lock washer and 3/8 nut and tightened as much as I could. I think this will work. I'll let you know, as we are expecting snow late this afternoon and evening (3-6" possible).
GEL
Edited by nycub122, October 29, 2011 - 03:51 PM.
#11 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted October 29, 2011 - 02:27 PM
I hope they work well for you. Glad you could get something figured out to hook them up. Good luck!
