For Sale
Cub Cadet 169 hydro
1 reply to this topic
#1 1oldbuzz OFFLINE
1oldbuzz
  • 586 Thanks
  • 465 posts
Posted March 22, 2018 - 02:24 AM
Repowered with a 14 horse kohler
engine has new piston/rings and gaskets
is also modified wide block (see brian miller pulling)
also has 1 1/8 crank stub so the current pto clutch will not work
Balance gears have been removed
Has hydraulic lift
I have the missing headlight. mount screws are broke off
have the matching rib turf tire needs the tube patched
has new voltage regulator
will need a battery
Does need a little TLC
needs a new drive shaft rag joint
needs a new choke cable
headlight fixed and headlights wired
sorry I do not have the tail light lenses
will include the pto clutch assembly
it will need a rebuild
$500
may consider selling as a roller for $250 no engine
sorry no attachments for it
for what its worth the chassis has been cleaned of debri
and machine was owned by the same party for 20 years
local pick up
willing to work out some transportation networking
#2 1oldbuzz OFFLINE
1oldbuzz
  • 586 Thanks
  • 465 posts
Posted April 03, 2018 - 12:56 AM
front tires now match (rib style)
choke cable has is repaired
headlight fixed and installed
they just need to be wired now
