its black already?
#1
Guest_jdecker94_*
Posted July 06, 2011 - 12:32 PM
#2
OFFLINE
Posted July 06, 2011 - 02:03 PM
I wouldn't go that thin on the next change. If anything, I would stay with manufacturers suggested oil, just with detergent.
#3
OFFLINE
Posted July 06, 2011 - 02:15 PM
#4
Guest_jdecker94_*
Posted July 06, 2011 - 02:25 PM
#5
OFFLINE
Posted July 06, 2011 - 03:33 PM
#6
Guest_jdecker94_*
Posted July 06, 2011 - 04:24 PM
#7
OFFLINE
Posted July 06, 2011 - 04:50 PM
#8
OFFLINE
Posted July 06, 2011 - 06:31 PM
seafoam is awsome, plain and simple and will get that engine clean again fast.:smile1: make sure she ain't running hot as well.
#9
Guest_jdecker94_*
Posted July 06, 2011 - 09:40 PM
#10
OFFLINE
Posted July 07, 2011 - 12:00 AM
#11
OFFLINE
Posted July 07, 2011 - 06:54 AM
#12
OFFLINE
Posted July 07, 2011 - 07:09 AM
Are you guys saying to use some seafoam along with some oil? How long would you run the motor befor changing the oil. I have read about you all putting it in your carbs, and gas tanks too. What is this stuff?
Sea Foam | Motor Treatment
#13
OFFLINE
Posted July 07, 2011 - 07:10 AM
It is a well formulated combination of Naptha, Acetone, and some other proprietary ingredients that work together to clean and stabilize ethanol gas. It also works very well as a cleaning agent in oil, with seemingly no I'll effects. There are directions on the can that tell you the amount to use, but I believe it's 2 oz in an larger oil change.
#14
OFFLINE
Posted July 07, 2011 - 10:56 AM
#15
Guest_jdecker94_*
Posted July 07, 2011 - 09:38 PM
