#1
OFFLINE
Posted March 15, 2018 - 10:08 AM
- Lmiller3358 and chieffan have said thanks
#2
OFFLINE
Posted March 16, 2018 - 08:25 AM
Those are plastic. If you want a similar one, you can get one from any ST/SS tractor 1976-1979. If you get an earlier one 73-75, it will be fiberglass and a little different shape, but they do not break as easy.
- chieffan said thank you
#3
OFFLINE
Posted March 16, 2018 - 11:00 AM
Any chance of making your own? I acquired a White 1655 a year ago that had the center dash busted up. Had all the fancy monitor stuff that is just something to look sat and cause problems. I removed it and cut one out using HD plex-a-glass. Even had the slot for the throttle arm which I cut out with a scroll saw. Working out good so far. I don't know the shape of the part your talking about so this "fix" may not work for you. good luck with your project.
#4
OFFLINE
Posted March 18, 2018 - 01:31 PM
#5
OFFLINE
Posted March 19, 2018 - 08:47 AM
I was sent a message by a guy who restores these older garden tractors and he said the dashboard i have is off a st18? How do i post pics on here to ask you guys if its the right dash or not?
A GT18 maybe? no such animal as a ST 18
What area is he from?
to post pics, hit the "more reply options" at bottom of reply box
Then click on Browse, find the pics on your phone or computer. Then hit attach this file.
once pic is attached, then you can "add to post". once you add all pics, then hit 'add reply"
Edited by TAHOE, March 19, 2018 - 08:48 AM.
- KennyP said thank you
#6
OFFLINE
#7
OFFLINE
Posted March 20, 2018 - 08:48 AM
Looks like the 76-77 dashes, looks like my 77 dash, well, except without all those cracks
#8
OFFLINE
Posted March 20, 2018 - 09:03 AM
If you don't care about keeping it original and just making it work, you can always mix and match stuff off different years. Not everything mixes and matches perfectly but many things do. You can always swap the dash hood and grill from an earlier version that is all aluminum. I am in the middle of doing a swapping of parts modification to a sears I have now to fit a bigger engine in it. I am not a collector, I just want my tractors to work so keeping it original is not what I am after, but everyone is different. So its just a suggestion.
#9
OFFLINE
Posted March 20, 2018 - 11:36 AM
#10
OFFLINE
Posted April 02, 2018 - 09:01 PM
#11
OFFLINE
Posted April 03, 2018 - 12:38 AM
I have an aluminum dash from a roper same thing
check you PM
#12
OFFLINE
Posted April 03, 2018 - 06:41 AM
First thing to do is check all your wiring, make sure none of it got mice chewed or is chaffed. You may have to pull flywheel tin and check the feed wire coming from the front of flywheel to the SSI module, they can get a bare spot and ground out module.
There should also be a 3 wire plug going to back of flywheel area, that has your 2 charge wires and the ignition kill wire. Unplug that, turn it over and then see if you have spark. If you do, then you know have an ignition switch issue.
Never spin motor without having the plug grounded to block, that can burn up a good module.
#13
OFFLINE
Posted April 03, 2018 - 06:24 PM
#14
OFFLINE
Posted April 03, 2018 - 08:53 PM
- TAHOE said thank you
#15
OFFLINE
Posted April 04, 2018 - 05:14 AM
1oldbuzz i dont know how to check pms lol.....sorry im a neebie....and ill start checkn the wiring thanks for the assistance again guys
A PM is a private message and shows as a # up by your user name (top right). Click on that to read the message. It is just between you two, we can not read PM's.
Also tagged with one or more of these keywords: Wanted, for free
Wanted
Trash and Treasures →
For Sale / Trade / Wanted →
Attachments →
Ariens GT 48 inch snowblower deflector cableStarted by 71mustangman , Yesterday, 01:56 PM |
Wanted
Parts →
20-8.00-10 tiresStarted by adamjd200 , Apr 15, 2018 |
Wanted
Attachments →
Quick Manufacturing Springfield Walk Behind Sickle Bar and moreStarted by JKochis82 , Apr 11, 2018 |
Found
Attachments →
Wanted Ariens GT snowplow dozerbladeStarted by skippy69 , Apr 07, 2018 ![]() |
Sold
Tractors →
I believe early 60's searsStarted by clinton99 , Apr 04, 2018 ![]() |
