MOW
17 replies to this topic
#1 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,305 Thanks
  • 1,938 posts
Posted March 13, 2018 - 02:52 PM
I do enjoy sharing my Railroad projects with all of you, but I'm sure at least some of you are getting board with looking at model's of steam locomotives ( I know I'm getting a little tired of building them right now. )
After all .. unless you're into theses things .. once you've seen a model of a steam locomotive being built, you've pretty much seen them all.
So .. I've decide to do a little work on some MOW equipment ( Maintenance Of Way, for those that are wondering what the letters stand for. )
While unpacking some of my stuff, I came across this crane that I had built way back in the 70's when I was was first trying to learn how to build with metal instead of plastic and soldering them together instead of gluing.
This is made out of tin ( using the metal from an old paint thinner can ) and small diameter brass rod.
I have learned a lot about soldering and working thin metal over the years and this model is a little crude compared to the standard that I set for myself now.
This is the crane.
I've taken the back cover off of it so I could put paint remover on it and get it down inside everything.
The first thing to do, was to separate the main parts of the crane.
You can see that the crane boom was mounted using two large terminals for electrical wiring.
The pulleys are made up from putting brass eyelets together on a rod.
I'm only going to modify this enough to make it look a little more realistic but still has some of the oddball things that I used when I first built it.
The base for the crane is a single sheet of tin that extends out the front ( where the boom is attached ) and hangs out past both side of the main body.
I trimmed both sides so they are flush with the main body of the crane.
The gear and pulleys at the top front edge are for the cables that raise and lower the boom.
Originally, I had the cable for the hook running up over the center of these pulleys and going under the center of the lift pulleys out on the boom and from there, on out to the end of the boom.
Now, I made up a bracket with two rollers and mounted it down closer to the base of the crane body.
I want to use a clam-shell bucket on this crane so the cables for it will come out between these two rollers.
A piece of brass is bent up on the ends to form the new mounting bracket for the boom.
I have also soldered 1/4 inch square brass tube to the underside of the base to make it thicker.
I machined a cover out of a piece of brass for the gear on top of the crane.
The cover makes it look a little more realistic and it also has a screw in the back of it that will keep the gear from rotating.
The gear is used to wind the two boom lifting cables up on the pulleys then tightening the screw will keep the cables from unwinding.
If you'll look back at the first photos, you'll see that the framework for the cab is made out of round brass rod.
I want to be able to put glass in this cab so I cut the brass rod out so it can be replaced with pieces of angle.
This side of the cab has a hole in it that was for clearance for the boom mounting bracket.
Here I'm forming the frame for the rear window behind the seat.
The top was also held in place by the brass rod so I decided to just get rid of it and make a new frame for the top from the brass angle.
The rear window frame is soldered in place.
The brass angle is used to form the windshield frame and the support for the top of the cab.
A new roof piece is soldered to the top of the cab.
Remember that hole in the lower part of the cab to clear the mounting bracket for the boom ?
I covered that with a piece of brass.
The I used some narrow strips of steel to frame out a door and soldered a strip of brass along the back side of the door.
This looks kind of gaudy but I think it will look okay once it is painted.
I also made up a door handle and put it on.
Here is how it looks so far with the cab mounted to the main body.
The front and rear window and the two angled side windows will have clear plastic in them for the glass.
I took three straight pins with the little round heads and soldered them to a piece of brass.
This is the panel with the control levers for inside the cab ( I know a real crane has more than three levers, but this cab only has room for three. )
This is mounted to the dash inside the cab.
  • olcowhand, wilberj, Gtractor and 15 others have said thanks
#2 boyscout862 OFFLINE
  • 13,693 Thanks
  • 9,476 posts
Posted March 13, 2018 - 03:00 PM
Craftsmanship is always interesting. Thanks, Rick
  • jdcrawler, KennyP, propane1 and 1 other said thanks
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,102 Thanks
  • 2,930 posts
Posted March 13, 2018 - 03:02 PM
Woohoo. Another build to follow!! :dancingbanana:  :dancingbanana:  :dancingbanana:
  • jdcrawler, KennyP, boyscout862 and 1 other said thanks
#4 KennyP ONLINE
  • 41,506 Thanks
  • 47,418 posts
Posted March 13, 2018 - 04:02 PM
I'm watching this! Ray, anything you share with us has always captured my attention! Drive on!
  • jdcrawler, boyscout862, TomLGT195 and 1 other said thanks
#5 RustyB ONLINE
RustyB
  • 190 Thanks
  • 94 posts
Posted March 13, 2018 - 04:17 PM
I'm not tired of seeing your builds. Keep them coming, I love the craftsmanship. Thanks for sharing and once again you made me think of my Dad.
  • jdcrawler and boyscout862 have said thanks
#6 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,332 Thanks
  • 10,293 posts
Posted March 13, 2018 - 05:20 PM
Great! At first, I thought you were going to join bbuckler in talking about your yard.
This a really interesting build. I wish I could solder that well.
  • jdcrawler, boyscout862 and TomLGT195 have said thanks
#7 jpswift1 OFFLINE
jpswift1
  • 802 Thanks
  • 620 posts
Posted March 14, 2018 - 12:14 PM
Wow, that's very cool!  You've certainly got some talent!
  • jdcrawler said thank you
#8 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,305 Thanks
  • 1,938 posts
Posted March 16, 2018 - 09:02 PM
I get most of my parts for working on my trains off Ebay, so I figured I would look there for a clamshell bucket for my crane.
This is the only one that I could find and it would cost $30 with the shipping, but I could have it within a couple of days.
It is the right size and it opens up, but it has more of a 'toy' look and there is no provision for a cable to go down to the hinge part part in the center to lift it up and close the two halves of the bucket.
I can order a much more realistic bucket from one of my catalogs but it would take at least a week for the order to be processed and the part sent to me.
Also, this bucket is of a much earlier design from the early 1900's and my railroad is set in the late 1940's time period.
So I decided to build my own bucket ( to be honest, I probably would have built it anyway because I'm to cheep to buy one. )
Starting with a piece of sink drain pipe, this will form the bottom 'curved' part of the bucket.
I squared the two sides on the lathe and I took a skim cut to remove the chrome plating.
Then I cut two sections from the drain pipe for the bottom panels of the two bucket halves.
The sides are cut from sheet brass and a brass washer is soldered to the hinge point on each piece.
Soldering the sides to the bottom panels.
Trial fitting the two halves of the bucket together and making sure they upen and close properly.
Here I'm fastening 'teeth' to the bottom edge of each half.
Each tooth is soldered onto the cutting edge of the bucket so it over laps the the other side just a little.
They are only soldered lightly so the solder doesn't flow across the surface of the whole tooth and stick it to the edge of the other bucket half.
Then two small holes are drilled thru the tooth and the bucket and two small brass pins are pushed thru them.
The long ends of the pins are cut off about 1/16 inch above the surface of the tooth.
This is place on the corner of the vice and the cut ends of the pins are hammered flat to form a tight rivet to hold the tooth in place.
The teeth are all attached, 3-teeth on one halve and 4-teeth on the other half.
I cut a brass rod to length and drilled and tapped the ends to form the pivot bar for the two bucket halves.
The pulley goes in the center of this bar and is free to spin on the bar itself.
I made up a triangular shaped housing with brass tubes soldered on each side of it.
This is the guard to keep the cable from coming off the pulley and it also keeps the pulley in the center of the bucket.
If you look close, you can see that each of the washers also have two rivets thru them to hold them in place because they are only soldered on 1/4 of each washer.
Here is how it looks so far with everything assembled.
All that was left was to make a top bar and attach the four arms to it and the corners of the bucket.
The arms are valve linkage parts from the 0-8-0 locomotive kit.
The operating cable to open and close the two bucket halves goes down the the small hole in the center of the top bar, then under the pulley and will be attached onto the underside of the top bar.
With the bucket hung from the hook in the center of the top bar, releasing the operating cable will let the center pivot bar drop and the two halves of the bucket will open up so it is only held by the cable attached to the top bar.
The open bucket is then lowered down so it sits on top of the dirt.
Then the operating cable is pulled back up and this lifts the pully on the center pivot rod up and causes the two halves of the bucket to close.
The teeth on the cutting edge of the bucket dig down into the ground as the two halves close so it digs a hole and fills the bucket with dirt.
The whole bucket is then lifted by the operating cable.
The cable attached to the top bar is also raised at the same time but is kept slack to keep the bucket closed.
To drop the dirt, either the cable to the top bar can be raised up to let the operating cable go slack and open the bucket .. or the cable to the top bar can be held still and the operating cable is then lowered to open the bucket.
A drag line from the crane will be attached to the chain that is hooked to one end of the bucket, to keep it from spinning on the cable and also to help position the bucket.
Edited by jdcrawler, March 16, 2018 - 09:07 PM.
  • wilberj, Gtractor, KennyP and 6 others have said thanks
#9 KennyP ONLINE
  • 41,506 Thanks
  • 47,418 posts
Posted March 17, 2018 - 05:58 AM
Nice craftsmanship on the bucket, Ray!
#10 TomLGT195 OFFLINE
TomLGT195
  • 4,102 Thanks
  • 2,930 posts
Posted March 17, 2018 - 07:06 AM
That is amazing, looks better than the bought ones. Plus the satisfaction of being exactly how you want it. You have a tremendous amount of patience to work with such tiny parts.
#11 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,305 Thanks
  • 1,938 posts
Posted March 17, 2018 - 06:46 PM
The gear that the crane is mounted on needs to be about 2 inches in diameter and looking thru my stuff, I didn't have any gears that big.
So I got on ebay and found a plastic gear that is made for people that build robots.
It came in the mail yesterday and I collected the rest of the parts that I need and started working on mounting the crane to a flat car.
I've already cut the flat piece of brass to size for the base plate and drilled a hole in the center of it.
This piece will be soldered to the underside of the crane and the gear and pivot mount will be attached to it.
I found the round brass piece on the bottom left already machined with the shaft sticking up from the base and it will be the pedestal mount that will be fastened to the deck of the flat car.
The other piece of brass will be the pivot bushing that will be mounted to the flat base plate.
The hole in the pivot bushing is drilled out to fit over the shaft on the pedestal.
One end of the bushing is then turned down to fit into the hole in the center of the base plate and the rest of the bushing is turned down so the gear fits onto it.
The bushing is soldered into the hole in the base plate.
The gear is set down over the bushing and fastened to the base plate with three small machine screws.
The pedestal fits into the bushing in the center of the gear.
At this point, the base plate is soldered onto the bottom of the crane.
I dug up a nice heavy duty flat car that someone had built back in the 40's or 50's and I'm going to mount the crane on one end of it.
The body of the flat car is made out of wood with an aluminum center frame.
The crane pedestal is positioned off center on the flat car so the deck area of the flat car sticks out past the side of the cab to make it easier for the operator to get in and out of the cab.
The screws that fasten the pedestal to the deck are positioned so they are threaded into the aluminum frame underneath.
One of the trucks on the flat car has steel wheels and the other truck has pot-metal wheels and they have started to disintegrate with age.
I took the truck apart and I'm replacing the pot-metal wheels with steel wheels that are the same age as the flat car.
Because my trans run on 2-rail track, at least one of the wheels on each axle has to be insulated.
Both insulated wheels have to be on the same side of the truck.
You can see a black mark on the center crosspiece, that mark means that side of the truck is insulated.
There is a mark right next to the insulated wheel on each axle so both of those wheels go to the side of the truck with the black mark on it.
Once the truck is mounted back on the aluminum frame, I have to make sure that both trucks have the insulated wheels on the same side.
With that all taken care of, I set the crane down on the pedestal to see how it looks.
Here you can see the area of the deck sticking out past the side of the cab.
The bottom of the gear has .020 clearance between it and the surface of the deck.
With the crane now mounted on the flat car, I can determine where to put the step to get up into the cab and also put a hand rail on the side of the cab in front of the door.
The base gear is almost as wide as the body of the crane, so the smaller gear that turns the base gear will be sticking out past the side of the crane.
Because of this, it needs to have a guard built around it and that is the next piece to build.
I took a section of brass angle and milled the center out of one side and it is formed to the radius of the base gear to form a flat guard panel with tabs to fasten it down to the deck of the flat car.
Then I took a piece of brass rod and machined it to fit up against the flat guard panel.
The two parts are soldered together to form a guard around the small gear and part of the base gear on either side of it.
This is fastened down on the deck of the flat car.
This is how it looks with the crane set back on the pedestal.
  • wilberj, KennyP, MFDAC and 5 others have said thanks
#12 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,332 Thanks
  • 10,293 posts
Posted March 18, 2018 - 07:27 AM
I was reminded yesterday of another odd piece of rail road equipment. Have you ever seen the machine that they use to clear roadway trees? It looks like an enormous weed whip with log chain for line. It's fearsome to watch!
#13 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,305 Thanks
  • 1,938 posts
Posted March 19, 2018 - 07:39 PM
I've never seen anything like what you have described .. it sounds like something that I would want to stand way back away from when it is running.
I can imaging a piece of that chain braking loose and flying thru the air.
#14 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 4,305 Thanks
  • 1,938 posts
With the crane now mounted on the flat car, I need to make a bracket for the boom to rest on when the crane is being moved from one place to another.
I cut a section of brass " I-beam " to the correct length and milled a slot in one end for the boom to fit into.
A piece of sheet brass will be the mounting plate and I've drilled holes in it to mount it on the deck of the flatcar.
Soldering the I-beam to the base plate.
The supports for the I-beam are made out of pieces of flat brass.
These are soldered to the boom support and then holes are drilled for ' rivets ' to fasten the parts together and make the boom support look more realistic.
Here is how it looks with the boom support mounted on the flat car.
  • KennyP, CRFarnsworth, TomLGT195 and 1 other said thanks
#15 TomLGT195 OFFLINE
TomLGT195
  • 4,102 Thanks
  • 2,930 posts
Posted March 20, 2018 - 03:17 AM
Amazing detail!
