Unknown mower deck
7 replies to this topic
#1 James Bosma ONLINE
James Bosma
  • 1,466 Thanks
  • 724 posts
Posted March 11, 2018 - 11:02 AM
Picked this deck up with a Murray Select rear engine rider 30 / 12
I know this is not the deck for the Murray
​Has 3 blades, think around 38 inch wide cut
​Also has garden hose hook up to clean underside of deck
I'm guessing Simplicity made
Any help is greatly appreciated
#2 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 9,996 Thanks
  • 3,237 posts
Posted March 11, 2018 - 11:08 AM
The gear box and shaft set up look like a newer Bolens tube frame style - they had a garden hose connection built into the deck.  Similar to this one which is an older style that has different lift arms and a few other differences.
  • James Bosma said thank you
#3 James Bosma ONLINE
James Bosma
  • 1,466 Thanks
  • 724 posts
Posted March 11, 2018 - 11:24 AM
Its in good shape and didn't want to see it get scrapped
Planning on selling it
What would the value of it be
#4 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 9,996 Thanks
  • 3,237 posts
Posted March 11, 2018 - 12:26 PM
Not sure on a value - if you can figure out a model number then see what a similar model is going for.
#5 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 9,996 Thanks
  • 3,237 posts
Posted March 11, 2018 - 12:59 PM
It could be this deck here if it is a 38" cut -  http://gardentractor...-18418-38inpdf/
I know the older decks had metal pieces around where the blades spin and the gearbox pulley is located (as per the picture)  - I am not sure if this model did or not originally.
Edited by 29 Chev, March 11, 2018 - 05:24 PM.
  • boyscout862 and James Bosma have said thanks
#6 EricFromPa ONLINE
EricFromPa
  • 3,992 Thanks
  • 3,259 posts
Posted March 11, 2018 - 03:17 PM
Bolens tube frame deck. It's missing the baffle and belt cover. Blades look newer.
#7 James Bosma ONLINE
James Bosma
  • 1,466 Thanks
  • 724 posts
Posted March 11, 2018 - 05:24 PM
I have only see the belt routing and under writers labels on deck
Was model number stamped in deck or a tag attached
Seems to look like a spot a tag was attached
#8 James Bosma ONLINE
James Bosma
  • 1,466 Thanks
  • 724 posts
Posted March 11, 2018 - 08:14 PM
I believe we hit the nail on the head with this one
Looks dead on to the 18418-38
Thank you
