I hear a funny squeaky noise?
27 replies to this topic
#1 BTS ONLINE
BTS
    Make Stuff Up
  • 4,743 Thanks
  • 2,667 posts
Posted March 07, 2018 - 07:12 PM
Ok I'm about out of ideas? My little '93 Mazda B2200 pickup has a squeak/squeal/chirp or whatever you would call it. The sound is coming from the driver side front wheel, I just now pulled the cap off the hub, it has plenty of grease, wheel is tight but not over tightened. When that front wheel is jacked off the ground, I can give the wheel a hard spin and it only does about 1 and a half turns before it stops. I would think it should spin better then that? The noise starts at around 30 to 40 MPH and it doesn't stop till the pickup slows down or stops. Anyone have any ideas? I am needing this pickup to go to Tulsa in a couple weeks and I want to make sure everything is on the up and up before I drive it 218miles.
I already replaced all the brakes and the front wheels bearings.
Thanks for any info
  • chieffan said thank you
#2 shorty ONLINE
shorty
  • 5,919 Thanks
  • 5,452 posts
Posted March 07, 2018 - 07:25 PM
You already checked my ideas. What about suspension?
  • BTS and chieffan have said thanks
#3 BTS ONLINE
BTS
    Make Stuff Up
  • 4,743 Thanks
  • 2,667 posts
Posted March 07, 2018 - 07:33 PM
I know right, after brakes and wheel bearings I'm out of ideas too.
It isn't the suspension, it's not that kind of squeak, it starts up quite at around 30mph and gets louder when you go faster. It doesn't matter if it's on a rough country road or nice pavement, the squeak doesn't change.
Thanks
  • shorty and chieffan have said thanks
#4 propane1 ONLINE
propane1
  • 9,732 Thanks
  • 4,511 posts
Posted March 07, 2018 - 07:45 PM
My first guesses are. Sticking brake wheel cylinder or Sticking calliper. Or sticking calliper sliders. If the wheel in not turning like it should, something is sticking and causing a brake squeal. Or the wheel bearing is adjusted to tight causing the drag on the wheel. Or the bearings are the wrong ones. Oh, and is it drum or disk brake. Just some ideas. Sounds like you covered them all thou.
Noel
  • boyscout862, BTS, Leonard VanCamp and 1 other said thanks
#5 CRFarnsworth ONLINE
CRFarnsworth
  • 5,215 Thanks
  • 2,270 posts
Posted March 07, 2018 - 07:49 PM
 I'm still thinking bearings.
Chirping could be the brake wear indicator.
Edited by CRFarnsworth, March 07, 2018 - 07:51 PM.
  • boyscout862, BTS and chieffan have said thanks
#6 chieffan ONLINE
  • 11,766 Thanks
  • 7,278 posts
Posted March 07, 2018 - 08:11 PM
My first thought would be the brakes are adjusted a bit to tight, or something is on the pad/shoe that is dragging.  How does the other front wheel compare as far as the spin test?  Make sure they are both the same.
  • boyscout862 and BTS have said thanks
#7 Cat385B ONLINE
    HAZMAT CAT
  • 14,454 Thanks
  • 10,184 posts
Posted March 07, 2018 - 09:01 PM
What happens when you apply light braking at 40-60 mph, does it pull?
  • BTS said thank you
#8 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,660 Thanks
  • 4,644 posts
Posted March 07, 2018 - 09:11 PM
No help, but if I could give you a ride in my 95 Camry I'm sure you would forget about the squeak and worry about the rear strut rattling in the trunk, the engine rattling noise at idle, and the passenger front tire thumping / vibration at around 60-75.
#9 FixItCharlie ONLINE
FixItCharlie
  • 581 Thanks
  • 366 posts
Posted March 07, 2018 - 11:06 PM
One question have you verified that is where the sound is coming from by having someone else ride with you. I have seen many times that a sound seemed to be from some place but when someone else is in the vehicle you find that the sound is some place else. Just a thought.
Charlie
#10 Xrperry ONLINE
Xrperry
  • 1,206 Thanks
  • 844 posts
Posted March 08, 2018 - 12:47 AM
U JOINT maybe?
#11 TAHOE OFFLINE
TAHOE
  • 8,337 Thanks
  • 5,818 posts
Posted March 08, 2018 - 08:01 AM
"It's a funny squeaky sound"
"you couldn't hear a dump truck driving through a nitroglycerine plant"
Just turn up the radio a little, the squeak will go away  :poke: :poke: :rolling: :rolling:
  • EricR and BTS have said thanks
#12 olcowhand ONLINE
  • 43,135 Thanks
  • 32,005 posts
Posted March 08, 2018 - 08:59 AM
Did you use the disc brake squeal eliminator paste that usually comes with pads?  It sure can make a difference.
  • KennyP and BTS have said thanks
#13 Jazz OFFLINE
Jazz
  • 2,704 Thanks
  • 1,564 posts
Posted March 08, 2018 - 02:31 PM
Dust cover? Most the bases been covered.
  • BTS, propane1 and Leonard VanCamp have said thanks
#14 propane1 ONLINE
propane1
  • 9,732 Thanks
  • 4,511 posts
Posted March 08, 2018 - 03:46 PM
Dust cover. Tried to think of that name yesterday. Ya. A rusted or loose one could cause a noise.
Noel
  • KennyP, BTS and Leonard VanCamp have said thanks
#15 Jazz OFFLINE
Jazz
  • 2,704 Thanks
  • 1,564 posts
Posted March 08, 2018 - 03:52 PM
Noel
Not to stray from thread too much but I repaired a dust cover on wifes Toyota car couple weeks ago. That tin plate sells for $330 per pair! And a job to replace. Some of the GM dust covers are offered as a 2 piece unit which makes for a quick and easy replacement for about $40 a pair
  • KennyP, BTS, propane1 and 1 other said thanks
