Should I sell my Speedex?
11 replies to this topic
#1 H16VANGUARD OFFLINE
H16VANGUARD
  • 17 Thanks
  • 18 posts
Posted March 04, 2018 - 09:50 AM
Have a S19 Speedex with a 4 spd trans & Tec electric start engine. Super clean no rust & good rubber. Has headlights, tail lite new wire reinforced drive belt new brake lining new steering wheel even new decals. Can't think of anything it lacks. Put in storage a while back now time to make a decision. Would need a battery & started. I got a big collection mostly bigger frames. I think it needs a new home. Just doesn't seem to fit in with the rest. Any ideas sure would be appreciated.FILE0034.JPG
  • boyscout862, oldiron1 and Leonard VanCamp have said thanks
#2 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,213 Thanks
  • 2,951 posts
Posted March 04, 2018 - 11:25 AM
nice tractor, you won't find those around here.
#3 H16VANGUARD OFFLINE
H16VANGUARD
  • 17 Thanks
  • 18 posts
Posted March 04, 2018 - 11:51 AM
Thanks. I done a total ground up. Cleaned the rear end out & fresh fluid - even replaced all the bolt hardware & new grease fittings. Figured I would store with no gas in it & put a new battery in when started. Even fabricated a new set of headlights. Pretty much like the day it rolled out of the plant in Ravenna. Time to take out of storage & not let it set anymore. Just don't get into the small ones & thought might be better in another's collection?
#4 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,305 Thanks
  • 10,284 posts
Posted March 04, 2018 - 01:51 PM
You must be a millennial. It's your tractor; make up your own mind.
  • boyscout862 and oldiron1 have said thanks
#5 boyscout862 OFFLINE
  • 13,689 Thanks
  • 9,474 posts
Posted March 04, 2018 - 01:52 PM
Some times you need the handy little ones. Its a shame to part with something that you put so much into. If you do sell it, in a few years you will kick yourself. Good Luck, Rick
  • karel said thank you
#6 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,955 Thanks
  • 5,145 posts
Posted March 04, 2018 - 01:59 PM
I just sold 2 Speedex's last weekend.
#7 TomLGT195 ONLINE
TomLGT195
  • 4,097 Thanks
  • 2,926 posts
Posted March 04, 2018 - 04:42 PM
It's your decision, but the fact that you're thinking about letting someone enjoy it because it doesn't fit into you're collection, sounds like you made up your mind and were just looking for reassurance that it was a good thing. Ultimately it's your decision and no-one can answer how you'll feel when it's gone but you!  Good luck , Tom
  • boyscout862 and 29 Chev have said thanks
#8 olcowhand ONLINE
  • 43,131 Thanks
  • 32,004 posts
Posted March 04, 2018 - 07:42 PM
Nope, we can't decide for you, but it sounds like you've pretty much decided, so all you have to do is pull that trigger.  I've sold some things in my time I thought I'd grieve over, but really, I never had a regret that really stuck.
#9 karel OFFLINE
karel
  • 2,420 Thanks
  • 1,540 posts
Posted March 05, 2018 - 03:32 AM
Tech electric start engine! That's a Plus!
Edited by karel, March 05, 2018 - 03:33 AM.
#10 H16VANGUARD OFFLINE
H16VANGUARD
  • 17 Thanks
  • 18 posts
Posted March 05, 2018 - 07:39 AM
Guess it's time to get off the fence & sell it. Storage areas are getting full & time to put aside feelings. Sometimes stuff is hard to part with but it's better that way lest I become a hoarder or worse. Don't know what it's worth or even if I want to invest in a new battery but mind is made up to sell. Thanks for your wisdom folks.
  • olcowhand, boyscout862 and TomLGT195 have said thanks
#11 TAHOE OFFLINE
TAHOE
  • 8,337 Thanks
  • 5,818 posts
Posted March 06, 2018 - 07:56 AM
I would like to sell mine, just need to clean it up and try to get it running first.
I have become a hoarder pretty bad, I've gotten to the point I need to clean up and get rid of a bunch of stuff
  • H16VANGUARD said thank you
#12 H16VANGUARD OFFLINE
H16VANGUARD
  • 17 Thanks
  • 18 posts
Posted March 06, 2018 - 08:30 AM
I restore them then park them in storage. It's more the challenge I enjoy & when complete then it's over until the next one comes along. We get attached but just makes sense to make room and let others enjoy also.
