Massey 14 project
#3
OFFLINE
Posted March 03, 2018 - 08:41 PM
- olcowhand, boyscout862 and propane1 have said thanks
#4
OFFLINE
Posted March 03, 2018 - 11:14 PM
- boyscout862 said thank you
#5
OFFLINE
Posted March 04, 2018 - 12:49 AM
GT Reproductions sell the bezel and other parts for Massey Ferguson Gt's, they are a member on this site
http://www.gtreprodu...s.us/parts.html
I got decals for maple hunter texas
http://maplehunterde...ferguson14.aspx
Red - use implement red
Silver - Rustelumn wheel silver
Gray- I go to the dealer and get the Flint Grey
Black- semi gloss black
I see there is a Cat 0 3 pt. hitch attached to the tractor
They are a rare find and worth a few dollars, check for the lock out straps
These at strong good working tractors
I have all the Massey attachments and a 12" Brinley Cat 0 plough
Download the operators and parts manual in the manual section and you will see the lock out straps and how to use them
A couple of years ago I bought a repo cast aluminum bezel
Hoping to find the guy and get more, no luck last year, maybe this year
In 1975 the grill screen changed from the steel perforated plate to expanded metal for better cooling
If yours have the perforated steel grill screen engine may have over heated at one time
In 1975 the lift cylinder under the tractor also changed size
- DMAX and MFDAC have said thanks
#6
OFFLINE
Posted March 04, 2018 - 12:55 AM
About the only thing missing I can see in those 3 picks are the connecting straps for the 3 pt. hitch
You can see them in the attached picture along with a lock out strap on the 3pt. cylinder so the lift cylinder under the tractor will work
Unfortunately you can not use both lift cylinders at the same time with factory set up hence the lock out straps
Edited by James Bosma, March 04, 2018 - 12:56 AM.
- MFDAC and Mark 149 J. have said thanks
#7
OFFLINE
Posted March 04, 2018 - 05:56 AM
Maple Hunter decals are good for this model, that’s what I used on mine.
For paint I prefer the correct colour MF paint, I guess I’m just picky. MF Red, Flint Gray Metallic, Silver mist, black is just semi gloss.
These had a Kohler in them unlike the 10/12, K321? 14hp. Engine parts are easy to come by, most of the rest of it isn’t too bad your not likely going to need much. That broken tail light on the rear might be a bit hard to find last i looked they were discontinued from Massey. The steering wheel doesn’t look correct to me. The mufflers are hard to find so hopefully yours is good.
#8
ONLINE
Posted March 04, 2018 - 06:14 AM
Noel
#9
OFFLINE
#10
OFFLINE
Posted March 04, 2018 - 08:32 AM
Fuel tank has been replace with a plastic one,
Are the tins there for under the dash,
don't forget ask about them, 3 pcs to cover the 3 sides
Other than that from the pics it looks like a complete tractor
Edited by James Bosma, March 04, 2018 - 10:39 AM.
#11
ONLINE
Posted March 04, 2018 - 08:55 AM
Noel
- James Bosma said thank you
#12
ONLINE
Posted March 04, 2018 - 10:32 AM
#13
OFFLINE
Posted March 04, 2018 - 10:38 AM
Hard to tell from the picture, but it looks like it missing the handle for locking the brake
Noel
Good eye propane1 I just saved and zoomed in and you are correct
Seems that assembly is missing, but the knobs are on the lift and hood latch levers
- propane1 said thank you
#14
OFFLINE
Posted March 04, 2018 - 01:43 PM
The left panel that is missing is where the serial number plate would be located. The side panels are difficult to find if they are missing. I was looking for a left one last year to replace one that was rusted out at the bottom. I ended up just welding in a new patch of sheet metal to replace what the rust had ate.
#15
OFFLINE
Posted March 04, 2018 - 07:08 PM
