What exactly do I have here?
simplicity broadmoor
3 replies to this topic
#1 sprintcar72 OFFLINE
sprintcar72
  • 20 Thanks
  • 11 posts
Posted March 02, 2018 - 06:57 PM
Based upon some research on the forum here, I assume I have a Simplicity Broadmoor. But, is it a 728, a 738 or what? I know the engine is not correct. It is a more modern 12 hp Briggs. The I.D. No. on the rear between the fenders is 577010953. Cheers, Mike
  • Mark 149 J. said thank you
#2 ACmowerguy OFFLINE
ACmowerguy
  • 459 Thanks
  • 387 posts
Posted March 02, 2018 - 08:46 PM
The MFR number is 990577. It is a 728 Broadmoor. One easy way to tell the difference between the 728 and 738 is the lift lever. The 738 had the bar and chain underneath the tractor rather than on the side of the lever. Also the 738's had the 3 spoke steering wheel while some of the 728's had a two-spoke wheel.
https://www.simplici...equested=990577
  • CRFarnsworth, boyscout862, TomLGT195 and 1 other said thanks
#3 ACmowerguy OFFLINE
ACmowerguy
  • 459 Thanks
  • 387 posts
Posted March 02, 2018 - 08:51 PM
Here is a view of a 738 for comparison:
#4 sprintcar72 OFFLINE
sprintcar72
  • 20 Thanks
  • 11 posts
Posted March 02, 2018 - 11:15 PM
Thank you for the info. It amazes me how much steel they used to put in them. Gonna sit on it for a while and maybe consider a restoration. Got some projects ahead of it in line though. Thanks again.
Sent from my iPad using Tapatalk
  • boyscout862, ACmowerguy and Achto have said thanks
