D600 governor
21 replies to this topic
#1 webn237 OFFLINE
webn237
  • 27 Thanks
  • 40 posts
Posted March 02, 2018 - 02:40 PM
Whats the safest rpm to run a kubota d600 without doing damage? We are running it and sounds like its around maybe 2000 rpm. The max rpm i read is 3600 rpm
Sent from my SM-G935R4 using Tapatalk
Edited by webn237, March 02, 2018 - 02:41 PM.
#2 secondtry ONLINE
secondtry
  • 2,242 Thanks
  • 1,582 posts
Posted March 02, 2018 - 02:52 PM
I see two pages of Kubota engine manuals in the manuals section third tab from the left top of this page. Have you tried there? Don
#3 pryan05 OFFLINE
pryan05
    LGT
  • 688 Thanks
  • 376 posts
Posted March 02, 2018 - 07:45 PM
Everywhere I seen is 3600RPM.
#4 olcowhand ONLINE
  • 43,135 Thanks
  • 32,005 posts
Posted March 02, 2018 - 08:12 PM
Yes, 3,600 rpm.   To dial it in, get a digital tach.  They are cheap and very accurate.
HERE is an ebay page with some.  The top 3 are just like the one I have and I've had it a good 3 years and still works fine.
  • Cvans and secondtry have said thanks
#5 Cvans ONLINE
  • 7,459 Thanks
  • 6,468 posts
Posted March 02, 2018 - 08:35 PM
It's probably just a feeling I have but I don't like the sound of a screaming diesel. Run most of mine between 2700 and 3200 RPM depending on the application. Usually go by how the engine sounds.
  • olcowhand said thank you
#6 olcowhand ONLINE
  • 43,135 Thanks
  • 32,005 posts
Posted March 02, 2018 - 09:41 PM
That's why I like my Kubota F3060 so much over my John Deere F935.  The Kubota is so much quieter, engine and deck, than the JD.  2700rpm vs 3600.  The Kubota engine at the slower engine speed is awfully nice.
  • Cvans said thank you
#7 webn237 OFFLINE
webn237
  • 27 Thanks
  • 40 posts
Posted March 02, 2018 - 09:44 PM
I just got a no touch tach today and says its running at 2700 rpm. I adjust the fuel screw right to get more rpm?0fac36fa70ed18dcac204759a50f1084.jpg57b9afd506461b09cdabbd3bb51eb722.jpg
#8 olcowhand ONLINE
  • 43,135 Thanks
  • 32,005 posts
Posted March 02, 2018 - 10:16 PM
You back off the throttle arm stop screw.
#9 Cvans ONLINE
  • 7,459 Thanks
  • 6,468 posts
Posted March 03, 2018 - 12:04 AM
:iagree:
#10 webn237 OFFLINE
webn237
  • 27 Thanks
  • 40 posts
Posted March 03, 2018 - 05:55 AM
So your talking about this screw correct? The very bottom one with the nut on it is the idle speed right?345df97d6c8a4ce97726979cfb831ad8.jpg
#11 olcowhand ONLINE
  • 43,135 Thanks
  • 32,005 posts
Posted March 03, 2018 - 09:48 AM
Yes, I do believe the circled one is your high speed limit stop.
#12 webn237 OFFLINE
webn237
  • 27 Thanks
  • 40 posts
Posted March 15, 2018 - 06:24 PM
Is that the same as the fuel adjustment screw? Or is that somewhere else?
#13 olcowhand ONLINE
  • 43,135 Thanks
  • 32,005 posts
Posted March 15, 2018 - 06:31 PM
Not the same.  Not sure where the fuel screw is for your particular engine, BUT it's best to leave it alone.  Putting more fuel in their can wash lube from cylinder walls, speeding wear, plus fouls oil faster.
#14 Cvans ONLINE
  • 7,459 Thanks
  • 6,468 posts
Posted March 15, 2018 - 09:51 PM
 I'm 67 and still like to see a little coal roll when the oil burner is under load.  :D
#15 webn237 OFFLINE
webn237
  • 27 Thanks
  • 40 posts
Posted March 15, 2018 - 11:32 PM
When i adjusted the throttle stop and it was reading at 3200 rpms it sounded like it was either missing or not getting enough fuel at WOT
