leaking oil seal on transaxle
7 replies to this topic
#1 Woodwagon OFFLINE
Woodwagon
  • 11 Thanks
  • 7 posts
Posted March 01, 2018 - 03:52 PM
I have a leaking oil seal on the drive shaft of my; white 16HP garden tractor  1974?  transaxle. Just wondering if anyone has changed these seals before and where they purchased the seal. I was to my local small engine dealer and they said the oil seal was discontinued. Pictures of shaft and transaxle provided.
  • boyscout862 and JohnDeere110 have said thanks
#2 dennym OFFLINE
dennym
  • 2 Thanks
  • 1 posts
Posted March 01, 2018 - 05:37 PM
That looks a lot like the peerless 2315 transaxle in my MTD 143-960 garden tractor.  If so, the part number is 788025 and it is discontinued.  I just did a Google for "peerless part 788025" and found at least one place that claims to have it (SWI TURF).  Try that and see what you can find.
  • boyscout862 and Woodwagon have said thanks
#3 Bolens 1000 ONLINE
  • 15,553 Thanks
  • 18,319 posts
Posted March 01, 2018 - 06:09 PM
looks like a peerless 2300 series there should be the model of the unit stamped on the center of the case somewhere.
I stock the seals as well as complete gasket and seal kits for these if needed
  • KennyP, boyscout862 and Woodwagon have said thanks
#4 olcowhand ONLINE
  • 43,149 Thanks
  • 32,006 posts
Posted March 01, 2018 - 06:17 PM
Looks to cross to an SKF 7628.
#5 Woodwagon OFFLINE
Woodwagon
  • 11 Thanks
  • 7 posts
Posted March 02, 2018 - 05:37 PM
transaxle serial #.jpg transaxle serial #.jpg (looks like a peerless 2300 series there should be the model of the unit stamped on the center of the case somewhere.
I stock the seals as well as complete gasket and seal kits for these if needed)
Thanks all for the replies. I cleaned up transaxle and found the tag with model (picture attached)
DR. Bolens, if you have a seal for this unit I would be willing to purchase one.
Keith
#6 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 10,416 Thanks
  • 3,376 posts
Posted March 02, 2018 - 05:43 PM
Looks like whatever goes onto the shaft was rubbing on the seal and transaxle case which would create heat and debris that may have been why the seal failed - you may want to check to make sure that what goes on the input shaft is not putting undue pressure against the transaxle case - just a suggestion so that the replacement seal does not end up failing.
#7 Bolens 1000 ONLINE
  • 15,553 Thanks
  • 18,319 posts
Posted March 03, 2018 - 08:00 AM
That would be the 2300 series that seal is the 788025 runs $ 4.63 send me a pm if interested
  • olcowhand said thank you
#8 olcowhand ONLINE
  • 43,149 Thanks
  • 32,006 posts
Posted March 03, 2018 - 09:40 AM
Great price on that seal Brian!
  • Bolens 1000 and Woodwagon have said thanks
