Dodge caravan spare tire rims modification
11 replies to this topic
#1 clark3251 OFFLINE
clark3251
  • 23 posts
Posted July 05, 2011 - 12:53 PM
What year dodge caravan do the rims come from when you are converting to rear ag tires? I am trying to modify my 1969 MF.
I went to junk yard and they said the rims are different according to years. They said that they were measure in mm not inches now.
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted July 05, 2011 - 01:09 PM
Not sure what year but the metric conversion for 5 on 4.5" bolt circle is 5 on 114.7 mm (some people say 114 mm, others may call it 114.5 mm, and then others call them 115 mm). Hope that helps. If not Tractormike will be along soon enough, he will know.
#3 clark3251 OFFLINE
clark3251
  • 23 posts
Posted July 05, 2011 - 03:33 PM
Thank you very much. I checked with the junkyard and that is the size they have. Thanks again
#4 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted July 05, 2011 - 04:31 PM
No problem clark, anytime you need help just ask, someone here will jump right in.
#5 EricFromPa ONLINE
EricFromPa
  • 4,006 Thanks
  • 3,266 posts
Posted July 05, 2011 - 04:48 PM
Dodge mini vans came with both 5x100 and 5x114.3 lug patterns.
I would tell you what years to look for if I wouldn't of misplaced my book.:wallbanging:
#6 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted July 05, 2011 - 05:33 PM
And this is why I hate the metric system, a simple 5 on 4.5 bolt circle has 5 different metric measurements depending on who you talk to lol
#7 Bentwrench OFFLINE
Bentwrench
  • 27 Thanks
  • 29 posts
Posted July 05, 2011 - 05:40 PM
Try this site for cross checking wheels.
Wheel Bolt Pattern Cross Reference Database and Conversion Guide
  • Bill56, tractormike, DGS345 and 2 others have said thanks
#8 caseguy OFFLINE
  • 1,629 Thanks
Posted July 05, 2011 - 06:55 PM
Thanks a million Bentwrench! THAT'S a useful tool! Thank you for posting the link!
#9 clark3251 OFFLINE
clark3251
  • 23 posts
Posted July 05, 2011 - 07:08 PM
Thanks to all for the help. Y'all do not disappoint.I will continue to look to y'all for help. I am slow to get to work on my tractors so it is usually a while between my posts. Thanks again
#10 cp7 OFFLINE
cp7
  • 59 Thanks
  • 148 posts
Posted July 05, 2011 - 09:26 PM
Here's another bolt pattern reference.
Vehicle Bolt Pattern Guide
  • Bill56, tractormike, ducky and 1 other said thanks
#11 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted July 06, 2011 - 06:59 AM
Thanks to bentwrench and cp7 for posted the bolt pattern guides. I didn't know what years fit. The junkyard that I get my rims from isn't that organized! When I go looking for rims they are all is a pile and I have to pick through them. I took my bolt pattern gauge along the first time to find out what rims would fit. If you look at the pictures of my narrow front tractors and notice the size and placement of the 18 round holes in the wheel disk that is what I look for. If you find a 15 inch rim with those 18 round holes in the disk part it should work. You will probably have to torch out the center rim flange to get it to fit the Massey hub as the garden tractor wheel center is a little bigger.
#12 scrapiron OFFLINE
scrapiron
  • 1 Thanks
  • 104 posts
Posted September 01, 2011 - 11:45 PM
hey thanks guys for those links very helpfull
