My new snapper 1650's
16 replies to this topic
#1 Nessmuk OFFLINE
Nessmuk
  • 9 Thanks
  • 45 posts
Posted February 27, 2018 - 07:15 PM
I bought 2 1650 tractors, both with 3 point, one with pto, and one engine.
Got the pto one to run. I need some info.
What the capacities?
What height should the implement tip link be At?
My pto belts don't seem right. Is 38 inch right?
Any help adjusting them would be great.
Regarding the front bull gears, I have two. They are both different, and both seem to be just separate idler pulleys. Is that right?
  • limebuzz, 101 senior and Sawdust have said thanks
#2 Nessmuk OFFLINE
Nessmuk
  • 9 Thanks
  • 45 posts
Posted February 28, 2018 - 09:28 AM
Also, I need all the plastic parts.
I am looking for help finding rib type front tires.
I may sell the parts one once I'm sure the other works.
Any info on modifying other implements to run off the pto?
I've got a deck and a donor deck I plan on modifying the donor to fit. I understand the timed spidle pulleys are unavailable.
  • limebuzz said thank you
#3 KennyP OFFLINE
  • 41,529 Thanks
  • 47,427 posts
Posted February 28, 2018 - 10:00 AM
:wave:  Welcome to the forum! I'm no MF guru, I'll leave that to the folks in the know. The V61's would work good on the front, but they are $.
#4 Dayton_King ONLINE
Dayton_King
  • 1,556 Thanks
  • 1,176 posts
Posted February 28, 2018 - 07:36 PM
I am a fan of v61s. They are 120 a set but are fantastic. But I am guilty of not doing cheap things lol.
  • limebuzz and Sawdust have said thanks
#5 Leonard VanCamp ONLINE
Leonard VanCamp
  • 684 Thanks
  • 483 posts
Posted February 28, 2018 - 09:55 PM
Is the tractor for strictly mowing? If so, go with the V61's. If your going to be doing snow removal get a set of tri-ribs. I have two sets of each and I find the tri-ribs are better for snow. The ones I got have a very tall center rib that helps with steering and traction.
#6 Nessmuk OFFLINE
Nessmuk
  • 9 Thanks
  • 45 posts
Posted February 28, 2018 - 10:36 PM
Field work mostly. Some side hill work. Maybe some year a mini loader.
#7 Leonard VanCamp ONLINE
Leonard VanCamp
  • 684 Thanks
  • 483 posts
Posted February 28, 2018 - 10:42 PM
Hmm, I'd lean to the tri-ribs, they also shed mud better and also work good for garden plowing. V61's are good for loader work, you can get thicker ply tires and they can spread the load weight out more.
#8 gtcsreg ONLINE
gtcsreg
  • 2,093 Thanks
  • 2,062 posts
Posted March 01, 2018 - 09:23 AM
I put the bar tread on mine because of turning on side hills.  Works much better than turfs.  (See my profile for photo).
  • Sawdust said thank you
#9 Nessmuk OFFLINE
Nessmuk
  • 9 Thanks
  • 45 posts
Posted March 01, 2018 - 10:01 AM
Thanks all.
Need to find another k341 now.
#10 Nessmuk OFFLINE
Nessmuk
  • 9 Thanks
  • 45 posts
Posted March 05, 2018 - 05:45 PM
The tune up and carb are in it. It runs! Needs adjustment tho.
Ordered rear tubes and an owner's manual.
It's all rewired too.
Waiting on the fronts unroll I drive it around and it all works.
  • Mark 149 J. said thank you
#11 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,913 Thanks
  • 1,619 posts
Posted March 05, 2018 - 07:37 PM
That is good news!
How about sharing some pictures with us so we can see what she looks like!
  • limebuzz and jimbobbillyray have said thanks
#12 Nessmuk OFFLINE
Nessmuk
  • 9 Thanks
  • 45 posts
Posted March 05, 2018 - 07:51 PM
I'd like air in the tires first. All the plastic is missing too. I'm going to have to build new out of tin.
Any source for decals?
#13 limebuzz ONLINE
limebuzz
  • 1,079 Thanks
  • 1,024 posts
Posted March 05, 2018 - 08:21 PM
Do you mean the dash is missing completely? Depending on what decals your after..... I have a few for the 1650
#14 Nessmuk OFFLINE
Nessmuk
  • 9 Thanks
  • 45 posts
Posted March 06, 2018 - 08:54 AM
Any decals esp. Massey ones for the hood.
I have no plastic.
#15 limebuzz ONLINE
limebuzz
  • 1,079 Thanks
  • 1,024 posts
Posted March 06, 2018 - 02:44 PM
All I have at the moment are dash decals and front grille
