Started a new Implement build
95 replies to this topic
#1 MNGB ONLINE
MNGB
  • 2,621 Thanks
  • 1,568 posts
Posted February 27, 2018 - 06:31 PM
Hi all, I started a new implement build and thought I'd post here rather then on the PK forum as this will be usable with any GT with a Cat 0 3 pt hitch So here's the $2.00 question what is it??
HPIM1820.JPG HPIM1821.JPG HPIM1822.JPG HPIM1823.JPG HPIM1824.JPG HPIM1825.JPG HPIM1826.JPG
  • Gtractor, hamman, KennyP and 5 others have said thanks
#2 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted February 27, 2018 - 06:52 PM
HMMMMM? With out dimensions to know which way it will sit when hooked to the 3-point, kinda hard to guess! Is the angle plate a digging tool?
  • boyscout862, MNGB, 29 Chev and 1 other said thanks
#3 MNGB ONLINE
MNGB
  • 2,621 Thanks
  • 1,568 posts
Posted February 27, 2018 - 07:09 PM
Hi Kenny yes its to go in the dirt and the taller uprights are where the 3 pt mounts will be attached
  • KennyP, boyscout862 and Mark 149 J. have said thanks
#4 chieffan ONLINE
  • 11,340 Thanks
  • 7,106 posts
Posted February 27, 2018 - 07:52 PM
Maybe some kind of dirt bucket?  What ever it is it's going to be heavy with all the 2" square tubing.
  • KennyP and MNGB have said thanks
#5 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 2,011 Thanks
  • 1,092 posts
Posted February 27, 2018 - 08:32 PM
Looks like a pond scoop in the making.
#6 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted February 27, 2018 - 08:48 PM
Not a clue what is being built, but will be following progress.
#7 James Bosma OFFLINE
James Bosma
  • 1,478 Thanks
  • 729 posts
Posted February 27, 2018 - 08:57 PM
Anything to do with Vodka maybee
#8 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted February 28, 2018 - 05:02 AM
A tater digger maybe?
  • Alc, propane1, MNGB and 1 other said thanks
#9 James Bosma OFFLINE
James Bosma
  • 1,478 Thanks
  • 729 posts
Posted February 28, 2018 - 06:22 AM
That's what came to my mind right off the hop
Couldn't see this implement used in hard packed soil, but I could be wrong
One 1 person knows for sure what it is at this moment
  • Alc and MNGB have said thanks
#10 MNGB ONLINE
MNGB
  • 2,621 Thanks
  • 1,568 posts
Posted February 28, 2018 - 08:37 AM
Good Morning all, you guys nailed it it going to be tater digger hopefully it will work as conceived
  • KennyP, SupplySergeant, James Bosma and 1 other said thanks
#11 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted February 28, 2018 - 09:25 AM
:dancingbanana:  I had it pegged (along with James)! Gonna have a screen to shed some of the dirt in there?
  • MNGB, James Bosma and Mark 149 J. have said thanks
#12 MNGB ONLINE
MNGB
  • 2,621 Thanks
  • 1,568 posts
Posted February 28, 2018 - 12:54 PM
Hi ya you guys must have put your thinking caps on :dancingbanana:  yes on the dirt grate, the plan is to use 1/2" rod approx 16" long with the aft 3" bent down spaced 1.5" apart still trying to work out a system to shake the grate one idea is a 12v motor and a cam with a rod attached to the grate another is to find a steel wheel about 6/8" in diameter and cut the spokes uneven turn the hub 180 degrees and that would make the grated move up & down got some welding done this morning
  • KennyP and James Bosma have said thanks
#13 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted February 28, 2018 - 01:06 PM
A steel wheel with a hole drilled out from center a bit would work. Attach a piece of strap iron to that and the grate. Works like a crank shaft.
  • SupplySergeant and MNGB have said thanks
#14 tater195 OFFLINE
tater195
  • 2,264 Thanks
  • 1,443 posts
Posted February 28, 2018 - 01:09 PM
I thought you were talking about me for a second.
They do make a 12 vibrating motor, not cheap though. https://static.grain...7_AS01?$mdmain$
#15 propane1 ONLINE
propane1
  • 9,442 Thanks
  • 4,384 posts
Posted February 28, 2018 - 02:51 PM
I too figured it was a tater digger. I grow taters and always lookin for better ideas for a tater digger. I will follow along and see the end result.
Noel
  • MNGB said thank you
