Ford lgt 165 new to me
35 replies to this topic
#31 galvprobigd OFFLINE
galvprobigd
  • 25 Thanks
  • 15 posts
Posted February 22, 2018 - 01:56 PM
Can you guys clear up which direction the fluid is flowing through this filter? Is it returning to the transmission or coming from it? And what fluid do you guys use to fill them with ? SAE30 motor oil? Or universal hydraulic/transmission tractor fliud?
#32 KennyP ONLINE
  • 41,454 Thanks
  • 47,383 posts
Posted February 22, 2018 - 02:58 PM
The fluid is going back to the transmission, that's why it's in the return line. I use the Universal fluid.
  • galvprobigd said thank you
#33 galvprobigd OFFLINE
galvprobigd
  • 25 Thanks
  • 15 posts
Posted February 22, 2018 - 05:52 PM
Thanks the P.O. had the filter in backwards. That kinda confused me a little. And would explained why the fitting is pushed out of the housing.
I'll stop and get a couple gallons of the universal fluid for when I change this out
#34 propane1 ONLINE
propane1
  • 9,731 Thanks
  • 4,511 posts
Posted February 22, 2018 - 07:33 PM
This is what I was told to use.
Noel
#35 galvprobigd OFFLINE
galvprobigd
  • 25 Thanks
  • 15 posts
Posted February 22, 2018 - 10:09 PM
Noel
I'll see if Rural king has any tomorrow. Thanks again for all the replies guys, I really appreciate all the help. Hopefully one day I'll be able to part some knowledge on some new members
  • propane1 said thank you
#36 galvprobigd OFFLINE
galvprobigd
  • 25 Thanks
  • 15 posts
Posted March 11, 2018 - 08:34 AM
got a filter installed, drained the fluid and filled it back up with universal tractor fluid. the old fluid was really clean but was unsure what it was.  found the motor mounts, seat pan mounts, and brake material at mcmaster-carr. still having trouble getting the motor to run smoothly. i believe its the valves not seating correctly as the exhaust was stuck open when i got it. soaked it in pb blaster and freed it up, got it running but it still pops and idles erradicly. im slowly getting there!
  • limebuzz, KennyP, Rock farmer and 2 others have said thanks
