Century fox help
centuryfox hydraulic
3 replies to this topic
#1 1970jacobsen OFFLINE
1970jacobsen
  • 1 Thanks
  • 4 posts
Posted February 17, 2018 - 01:43 PM
I found a complete century fox lift setup on and older Jacobsen bit I want to put it on my 1970 Jacobsen that I use. My problem is the shaft size is smaller on my 1970 then the older jacobsen. I realize these parts are hard to come by but does anyone have one of these nuts or know of a way to make this work like a Helicoil. Thanks in advance
#2 Sammoore13bolens1053 ONLINE
    Because I’m young doesn’t mean I’m stupid
  • 186 Thanks
  • 278 posts
Posted February 17, 2018 - 05:00 PM
Hi, nice find, but I don’t know anything about this model.
#3 Dayton_King OFFLINE
Dayton_King
  • 1,550 Thanks
  • 1,174 posts
Posted February 17, 2018 - 05:10 PM
The k181 and k301 use the same crank bolt. The k241 has a larger nut like you found out. We have done 2 things. One is a helicoil the second was I went to Ace hardware and picked up one of those bolts that you put althread in and can tighten and loosen. We turned down a bolt and keyed it to take the pulley.
Sounds like you have a k241 crank pulley. I tried to trade mine for a k301 and no one had one. Best to modify.
#4 MM MARK OFFLINE
MM MARK
  • 82 Thanks
  • 38 posts
Posted February 19, 2018 - 08:50 PM
find a good machine shop and let them make the part correct than you don`t have to worry about the flywheel coming loose.
It may cost more than a helicoil but it will be right since you use the tractor. You have the part, you just need different threads the machine shop doesn`t need to reinvent the wheel to make it.
  • HALFSCALE said thank you
Also tagged with one or more of these keywords: centuryfox, hydraulic
