Montgomery Ward tractors
4 replies to this topic
#1 twowheeler63 OFFLINE
twowheeler63
  • 41 Thanks
  • 33 posts
Posted February 16, 2018 - 10:03 AM
Just when I think I am on the right track, along comes this.
According to the MW catalog images and descriptions, the Hoe-trac Standard, was based on the Simplicity L line, but this is an F series. The Hoe-trac Deluxe, was a Midland based tractor. The chase continues.....
  • Gtractor, boyscout862 and Mark 149 J. have said thanks
#2 boyscout862 OFFLINE
  • 13,689 Thanks
  • 9,474 posts
Posted February 16, 2018 - 12:55 PM
The model # on that plate appears to start with "SIM" which means that it is a Simplicity. Have you thoroughly gone through our Manuals Section? You need to look through "Simplicity", "MW", Walkbehinds, and Miscellaneous. Good Luck, Rick
Edited by boyscout862, February 16, 2018 - 12:56 PM.
#3 karel OFFLINE
karel
  • 2,420 Thanks
  • 1,540 posts
Posted February 17, 2018 - 03:27 AM
I have a wards midland. just use the midland manual.
Edited by karel, February 17, 2018 - 03:28 AM.
#4 GWest OFFLINE
GWest
  • 558 Thanks
  • 511 posts
Posted February 17, 2018 - 05:11 AM
What is the 87-xxxx number under the word Garden?
Garry
#5 twowheeler63 OFFLINE
twowheeler63
  • 41 Thanks
  • 33 posts
Posted February 21, 2018 - 07:47 AM
Garry, It's not my photo, it's one I found online. I can't make out the numbers either.
It doesn't seem to match anything I have, nor what you had put together earlier, on the yahoo groups.
boyscout862. I know it's a Simplicity based model, from the F tractor line, however, as I stated, nothing matches in the information I have. That said, I do not have a copy of the MW catalog from 1957. There is no mention of a Hoe-trac available in 1958, so this one may be a 1957.
karel. Thanks, but this isn't a Midland based tractor, and I don't have it personally, I'm just being nit picky, and trying to document Simplicity/Wards/Midland walkbehinds, because that's what most of mine are. I've nothing to gain, except some brain exercise. 8).
