Peerless 2300 strange problems fixes
3 replies to this topic
#1 MacWorld ONLINE
MacWorld
  • 104 Thanks
  • 129 posts
Posted February 15, 2018 - 11:50 AM
This transmission is used, at least, in the John Deere 200, 208, 210, 212, 214 and 216. May be other models and brands I don't know.
I encountered some problems with my 214, I will explain those and the causes/solutions.
First sometimes the transmission locked itself... in this situation if you release the clutch the engine will die as the transmission is locked! Over time I found that the problem presented itself only if I was using 3rd or 4th gear. Also at this point if you put the shifter arm to neutral, the tractor will be able to move but only in the gear that got engaged, most of the time 2 or R. You will NOT be able to return the R-N-2-1 to neutral! If you get in this situation, a temporary fix is to remove the shifter arm from the transmission (after removing the %$#?%#$? fender deck), move the fork to align it with the 3-4 fork and reinstall. At this point use only R-N-2-1.
The problem originates in the transmission. There are 2 forks, one of them moving a gear between 4 positions to make the R-N-2-1 ratios. In both forks there is a ball pushed by a spring that engages on the fork's shaft to "lock" it in the selected position. The spring was broken in the fork. When the transmission is selected to 3rd or 4th, nothing prevents the R-N-2-1 fork/gear from moving due to the tractor angle and/or vibration. If it moves, you will have 2 gears selected! Also, if it moves, you will be forever locked in the gear.
This problem may appear "opposite" to that, if the 3-N-4 fork spring breaks, the 3rd or 4th may select itself!
The solution is to replace the spring M40350, they are inexpensive. Don't be as stupid as I was, replace both springs. Might be a good time to replace both outer axle bearings!
Next problem began after replacing the spring and might be specific to JD tractors. The 2nd gear was unselecting itself at random times. The problem is that the R-N-2-1 fork's ball cannot reach the groove in it's shaft.
The solution is easy (but I found it after removing the %$#?%#? fender deck), you must realign the Quadrant. That's the metal part AM37574 or AM37575. Under the tractor there are 2 bolts holding this quadrant in place, they are between the frame rails under the fender deck right in front of the quadrant. Adjusting this part at the right place doesn't seem to be documented but you can do it logically. The shifter arm must move in the center of the quadrant's guides without touching it AND when the plastic "gate" (M48774) is down, the shifter arm must move just enough so that the fork's ball "clicks" in it's shaft groove.
Am I the only one to hate how JD made the fender deck so hard to install/remove on those tractors? %$#?#$?$@#.
  • olcowhand, lyall, CRFarnsworth and 3 others have said thanks
#2 boyscout862 OFFLINE
  • 13,692 Thanks
  • 9,475 posts
Posted February 15, 2018 - 02:37 PM
Thankyou for the descriptions of problems and solutions. When I have Peerless problems I go to the shop manuals for them. They help to figure the problems out. You can download the Peerless Manuals from our Manuals Section(3 for free per day). Good Luck, Rick
  • MacWorld said thank you
#3 MacWorld ONLINE
MacWorld
  • 104 Thanks
  • 129 posts
Posted February 15, 2018 - 02:57 PM
boyscout862 : I must admit I did't think about searching for the manual of the transmission directly! Thank you for this hint, I will have to see if the manual for the transmission of my Massey Ferguson 1655 is available!
#4 boyscout862 OFFLINE
  • 13,692 Thanks
  • 9,475 posts
Posted February 15, 2018 - 06:55 PM
The manuals are under the tractor brand and in the section for transmissions. The old sales brochures are fun to look through too. Good Luck, Rick
