Wisconsin engine - $100 (Thompson, CT)
3 replies to this topic
#1 boyscout862 OFFLINE
  • 13,693 Thanks
  • 9,476 posts
Posted February 15, 2018 - 07:17 AM
Interesting, but I don't need anymore(unless it was a freebie). Probably the correct engine for some walk behind. Good Luck, Rick
https://newlondon.cr...6496965753.html
Wisconsin engine - $100 (Thompson)
<image 1 of 1>
condition: fair
make / manufacturer: Wisconsin
model name / number: Water pump
Wisconsin small engine water pump turns over no spark
#2 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,972 Thanks
  • 5,148 posts
Posted February 15, 2018 - 07:21 AM
Water pump engines have a special crankshaft and they don't work on anything else.  :(
#3 boyscout862 OFFLINE
  • 13,693 Thanks
  • 9,476 posts
Posted February 15, 2018 - 11:38 AM
I haven't run into that. The older engines, and that looks like from the 50s, that I've disassembled, were straight shafted. This includes a 1950s 1 1/2 hp B&S water pump and a 1960s 10 hp B&S generator.  It was many years ago but I'm pretty sure they were straight. My first tapered crank was in the 1980s on Coleman generators. It is surprising how many people won't put oil in a new engine. Now, I'm curious about if that engine has a tapered crank. Good Luck, Rick
#4 adamjd200 OFFLINE
adamjd200
  • 2,119 Thanks
  • 2,223 posts
Posted February 15, 2018 - 12:02 PM
If it were closer I'd be after it for the air cleaner for one of mine.
