Rear lift for a 1920h
#1
OFFLINE
Posted February 14, 2018 - 08:09 PM
- Dince said thank you
#2
OFFLINE
Posted February 15, 2018 - 06:42 PM
#3
OFFLINE
Posted February 16, 2018 - 04:48 AM
#4
OFFLINE
#5
OFFLINE
Posted February 22, 2018 - 04:48 PM
#6
OFFLINE
Posted February 22, 2018 - 08:53 PM
Mine is pretty much custom built but many parts for the JD 318-400 stuff can be modified to work. It was to much money for me to buy a jd kit then modify it the way I wanted it to work. My 3pt now uses two cylinders and can lift my yard cart 275 lbs and me 225 lbs for a 500-550 total lifting behind the pins. JD tractors that use our same peerless rear had plates that bolted on the bottom where our hitch goes, This was the lower arm mounting locations.
#7
OFFLINE
Posted February 22, 2018 - 09:50 PM
I seen this, I wonder if anyone has adapted this other brand tractors or if it could be adapted.
https://www.searspar...rBoCDQcQAvD_BwE
Sent from my iPad using Tapatalk
