Help with liner actuator
8 replies to this topic
#1 dvx216 OFFLINE
dvx216
  • 17 Thanks
  • 5 posts
Posted February 14, 2018 - 01:50 PM
So my wife is looking at the 7112 and her question is how hard will it be to lift the deck and honestly I'm not sure if she crazy about lift it.So any info on what length how many pound rating of electric actuator to use would be appreciated.
#2 boyscout862 ONLINE
  • 13,548 Thanks
  • 9,427 posts
Posted February 14, 2018 - 03:49 PM
Lifting a deck is usually easy. It is other attachments that get harder. Fortunately, Simplicity has a very clever assist for the lift. If you put a "stinger" weight in the rear lift adapter, it will make the deck easier to lift. If you need more help, add a donut weight to the stinger. If you need more help, add another donut. The weights in the rear lift help with lifting attachents under the tractor and on the front of the tractor. Check out the manuals in our Manuals Section(three free downloads per day. You can improvise the rear weights with a 12" - 16"  bar and and some gym weights. Good Luck, Rick
  • Sawdust said thank you
#3 SimplyRad OFFLINE
SimplyRad
  • 1,292 Thanks
  • 939 posts
Posted February 15, 2018 - 09:25 AM
The deck is the easiest to lift. Adding weight to the rear lift will just make it harder to lift.
#4 toppop52 ONLINE
toppop52
  • 5,532 Thanks
  • 4,901 posts
Posted February 15, 2018 - 09:48 AM
To answer the original question, I never get less than 500# actuators, the cost isn’t that much different from 500-1000, as long as you use stops there’s no such thing as too much, then if you use it on something else later it’ll be more useful.
#5 haykarenhardy OFFLINE
haykarenhardy
  • 56 Thanks
  • 30 posts
Posted February 15, 2018 - 10:57 AM
The deck is the easiest to lift. Adding weight to the rear lift will just make it harder to lift.Check out manuals
Check out manuals sections on 7100 series rocker shaft, rear lift cable can be re located to counter balance deck or front mounted accessories.
Stan
#6 SimplyRad OFFLINE
SimplyRad
  • 1,292 Thanks
  • 939 posts
Posted February 16, 2018 - 09:56 AM
Stan
I will have to check that out.
#7 dvx216 OFFLINE
dvx216
  • 17 Thanks
  • 5 posts
Posted February 17, 2018 - 05:30 PM
Well after looking at electric actuators I got a price for a used hydraulic system off a 7117h for $180 which will bolt right up to my tractor so I'm thinking of going that route instead
  • olcowhand, toppop52 and Leonard VanCamp have said thanks
#8 olcowhand ONLINE
  • 42,896 Thanks
  • 31,939 posts
Posted February 17, 2018 - 05:52 PM
For that price, you'd be nuts not to!
#9 toppop52 ONLINE
toppop52
  • 5,532 Thanks
  • 4,901 posts
Posted February 17, 2018 - 06:39 PM
Hydraulic is a better choice usually.
