Argon/Co2 Tank Info
11 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted February 14, 2018 - 10:52 AM
I'm building a mig welder cart but won't be getting the tank until later. I'm thinking about the 125lb size. To finish my cart I need to know the diameter of the tank to make the holder on the cart. From what I can find from size charts online they show the 125lb.tank being 6.8" My thoughts are making the bottom ring on the cart 7" would be good. Thanks for the help.
  • hamman said thank you
#2 chieffan ONLINE
  • 11,341 Thanks
  • 7,106 posts
Posted February 14, 2018 - 10:54 AM
Better an inch to big than 1/4" to small.
  • hamman, boyscout862 and Sawdust have said thanks
#3 secondtry ONLINE
secondtry
  • 2,158 Thanks
  • 1,531 posts
Posted February 14, 2018 - 11:35 AM
I am with Chieffan. If it is a little loose when you get the tank you can glue a strip of rubber in it to take up the slack. Don
#4 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted February 14, 2018 - 11:44 AM
I went out & did some measuring I agree 7" would be too risky. I think I'll go with 7 1/2". Thanks guys
  • hamman and boyscout862 have said thanks
  • 14,888 Thanks
  • 15,514 posts
Posted February 14, 2018 - 12:12 PM
All my Miller welders have the opening for the tank that's about a 12" x 12" square, the thing that really keeps the tank secure is the adjustable chain on the top of the welder about half way up the tank. By having this setup I can use any size, 125-300  75/25% tank and it will stay secure in the welder.
  • jms180, hamman, KennyP and 3 others have said thanks
#6 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,597 Thanks
  • 2,908 posts
Posted February 14, 2018 - 12:59 PM
I posted a build of a wire welder cart back in 2014 . I used a metal box that was 10" X 10" for the 125 cfm tank. There are pics of it there if you want to take a look at them. Good luck. Anxious to see the completed cart.        Roger
  • Texas Deere and Horse and Sawdust have said thanks
#7 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 14, 2018 - 01:15 PM
I measured my Arogon/CO2 bottle and it is right at 7 inches.  I measured my oxygen bottle and it is right at 7 inches also so it must be a standard for size.
  • hamman and Sawdust have said thanks
#8 olcowhand ONLINE
  • 42,897 Thanks
  • 31,941 posts
Posted February 14, 2018 - 01:32 PM
Yep, 7".
  • Texas Deere and Horse, hamman, KennyP and 1 other said thanks
#9 JBRamsey OFFLINE
JBRamsey
  • 1,568 Thanks
  • 878 posts
Posted February 14, 2018 - 05:59 PM
My welder used to end up in the bed of my truck for side jobs. I put a chain near the bottom and just over halfway up the tank with a long screw hook and a lock nut. I can snug the chains up against the tank so it doesn't go anywhere.
I wouldn't fool with a ring.
  • Texas Deere and Horse, hamman and Sawdust have said thanks
#10 Texas Deere and Horse OFFLINE
  • 14,888 Thanks
  • 15,514 posts
Posted February 14, 2018 - 06:36 PM
That's the standard DIA of the 125 CF which is what most folks use. When I have a big job with lots of welding I often times rent a couple 300 CF bottles so I'm not switching out every 3 to 4 days.
  • hamman, KennyP, EricR and 1 other said thanks
#11 EricR ONLINE
EricR
  • 716 Thanks
  • 428 posts
Posted February 14, 2018 - 07:26 PM
The 300 size cylinder is good for you as the end user but to me (the filler) it sure is a pain to fill and lift and move around, lol...
#12 EricR ONLINE
EricR
  • 716 Thanks
  • 428 posts
Posted February 14, 2018 - 11:46 PM
And not to get to far off topic, my co-workers and I filled over 9,400 cylinders last month, sure makes for long weeks, LOL...
