Broke that pretty good
back blade
11 replies to this topic
#1 TAHOE ONLINE
TAHOE
  • 7,973 Thanks
  • 5,674 posts
Posted February 09, 2018 - 08:16 AM
I was pushing snow with the back blade and tore it up nothing but good. Guess that ole suburban torque was just too much for the Craftsman back blade. Well, that and it didn't help I rammed a railroad tie. :wallbanging:  I was trying to push snow up and over and was a little late raising blade. The blade just caught the top of the RR tie and tractor pushed the blade down at an angle thus bending and breaking mounts.
I make the declaration that snow is over for this winter, I'm outta salt and I broke my blade :D :D
How would you guys fix this? I am thinking of removing the flat bracket, using some thick angle instead to mount to upper box mount which will help prevent bending and I can bolt down through top also. Then I can weld the 2 flat bar from hitch to that also putting in some short piece of angle iron on the angle to new piece. Maybe weld a piece of angle lengthwise on the flat bars too from hitch to new piece.
  • olcowhand, Gtractor, hamman and 5 others have said thanks
#2 KennyP ONLINE
  • 38,285 Thanks
  • 45,886 posts
Posted February 09, 2018 - 08:23 AM
Ouch! I think I'm following what you plan for a fix. Replacing that flat bar with angle would help a lot! But then you might bend it elsewhere!
  • Alc, hamman, boyscout862 and 2 others have said thanks
#3 boyscout862 ONLINE
  • 12,841 Thanks
  • 9,165 posts
Posted February 09, 2018 - 08:35 AM
I agree with Kenny, you could cause more trouble. Take it apart, straighten the bracket, weld it up, and reassemble. It could be worse. The early AC/Simplicity tractors had a snow plow that wasn't spring loaded. If you hit something, the frame would break where it attached to the BGB. Look close at any of those old tractors and you will see that about half of them have been welded back together. Good Luck, Rick
I think that I would make a plan of it to be able to manufacture another, just in case.
Edited by boyscout862, February 09, 2018 - 08:36 AM.
  • Alc, hamman and TAHOE have said thanks
#4 Sawdust OFFLINE
Sawdust
  • 5,653 Thanks
  • 3,367 posts
Posted February 09, 2018 - 08:52 AM
I would get rid of the flat stock between your hitch & square bar. Mount your hitch plate the same way you have the other one. Remove the flat stock ribs between your square bars & add some angle stock across like ribs with at least two near the hitch plates.
  • hamman and TAHOE have said thanks
#5 HANKG ONLINE
HANKG
  • 6,307 Thanks
  • 3,421 posts
Posted February 09, 2018 - 09:25 AM
:deadhorse:           Buy a good one and be done with it. :smilewink:
  • hamman said thank you
#6 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted February 09, 2018 - 09:44 AM
Two springs and turn it into a trip blade?
  • hamman and Rock farmer have said thanks
#7 TAHOE ONLINE
TAHOE
  • 7,973 Thanks
  • 5,674 posts
Posted February 09, 2018 - 09:57 AM
I've got a trip blade for the front, but my winch quit working so I was pushing in reverse with my box blade, I removed the side wings. This is the blade I dress my gravel drive with also, I have a set of teeth that go on it to bust up the packed gravel. Had my winch been working, I wouldn't have been using it for snow.
  • olcowhand, hamman, Cat385B and 1 other said thanks
#8 James Bosma ONLINE
James Bosma
  • 1,317 Thanks
  • 652 posts
Posted February 09, 2018 - 11:24 AM
Is it possible to remove the flat bars and weld / bolt the hitch bracket right to the box blade
Would the blade still rotate 180 degrees if shortened up
Being a little shorter allows for tighter spots
#9 TAHOE ONLINE
TAHOE
  • 7,973 Thanks
  • 5,674 posts
Posted February 09, 2018 - 12:04 PM
I have thought about shortening it up, blade barely hits right now so no sure. I would have to mock it up
  • James Bosma said thank you
#10 secondtry OFFLINE
secondtry
  • 1,879 Thanks
  • 1,379 posts
Posted February 09, 2018 - 12:26 PM
  I'm with Kenny and Boyscout.  Something is going to give some place, it could get worse. Don
#11 JBRamsey OFFLINE
JBRamsey
  • 1,444 Thanks
  • 827 posts
Posted February 09, 2018 - 12:47 PM
I would repair it back to original and stop running into railroad ties.
  • KennyP, Cat385B, boyscout862 and 2 others have said thanks
#12 EricFromPa ONLINE
EricFromPa
  • 3,654 Thanks
  • 3,112 posts
Posted February 09, 2018 - 05:52 PM
Wow that's one Super Cheap built blade there itn't it?  After seeing how cheaply made that blade is I think I would try to build one from scratch. Can't me any worse could it? lol
