16/18 fiberglass
4 replies to this topic
#1 abu507 OFFLINE
abu507
  • 11 Thanks
  • 37 posts
Posted February 08, 2018 - 07:49 AM
Plowing snow is all I do with it does awesome job. The part that latches the blade to angle that goes in notches broke. Picked spring up off the ground broke. Any one know or got a pic of what i need to order to replace most of it. Frozen snow in it haven't thawed it out yet to see what all is in there.
  • chieffan said thank you
#2 secondtry ONLINE
secondtry
  • 1,879 Thanks
  • 1,379 posts
Posted February 08, 2018 - 10:15 AM
Pictures?  Don
  • abu507 said thank you
#3 Beef OFFLINE
Beef
  • 44 Thanks
  • 50 posts
Posted February 08, 2018 - 10:53 AM
Call Mission tractors in IND. They own the power king name. Its called Mission Manufacturing. I bought my blade from them, and I think they will have the parts you need.
  • CRFarnsworth and abu507 have said thanks
#4 Beef OFFLINE
Beef
  • 44 Thanks
  • 50 posts
Posted February 08, 2018 - 10:55 AM
Not seeing it but being a Millwright can't you have it welded up?
#5 MNGB ONLINE
MNGB
  • 2,114 Thanks
  • 1,405 posts
Posted February 08, 2018 - 08:20 PM
Hi abu507, looking at the master parts manual the latch looks to be the same as what was used on all the dozer blades since the middle 70's and is basically just a piece of flat stock steel about 1.2" X 2" X 2"  with a couple of holes drilled in it one for the spring and one for the hinge then there is a plain washer welded ti the aft side to connect the rope to, the spring is more complicated but  a simple spring could probably be  made to work I'll attach a dozer plow manual
Attached File  Spring Trip Bulldozer.pdf   954.44KB   7 downloads
