Case 448 info?
11 replies to this topic
#1 Firemang OFFLINE
Firemang
  • 187 Thanks
  • 197 posts
Posted February 08, 2018 - 02:34 AM
I’ve got my eye on a Case 448 that needs a ton of work/parts. If I bought it I intend to build a loader for it. It’s missing the hydraulic pump so I figured why not beef it up so it could run the tractor AND loader. My question is what size pump came stock on this machine and what type was it, i.e. vane, gear, etc? I’m trying to estimate how much I’d have into it and if it’s something I want to take on. Thanks
#2 HANKG ONLINE
HANKG
  • 6,592 Thanks
  • 3,529 posts
Posted February 08, 2018 - 08:22 AM
My 155 has a gear pump which is smaller I would imagine, its a Borg Warner Wooster div. pump and is pricey if  you can find one. Even used their not cheap with no guarantee it will last, the most daunting task would be to find a new pump with the inlet and outlet of the same size's in the same position. Then there is the control valve and the motor to be concerned with, a repair manual and parts list are a must. I'm not trying to discourage you just pointing out some facts, their great tractors.
  • Firemang said thank you
#3 Firemang OFFLINE
Firemang
  • 187 Thanks
  • 197 posts
Posted February 09, 2018 - 02:05 AM
I’m just trying sort out how much I’d have into it, it’s missing alot, needs to get completely torn down, sand blasted, paint, tires, new motor (was gonna use one of the HFT 22 hp Honda clones), the works!
#4 HANKG ONLINE
HANKG
  • 6,592 Thanks
  • 3,529 posts
Posted February 09, 2018 - 09:17 AM
In my humble opinion, I would spend the money on one that's up and running.
#5 50cal OFFLINE
50cal
  • 1 Thanks
  • 2 posts
Posted February 10, 2018 - 09:03 PM
Way better to find a 600 series with a loader . The 400 series frame is not heavy enough for a loader.
#6 dropped82 ONLINE
dropped82
    Nut Case
  • 2,738 Thanks
  • 1,903 posts
Posted February 11, 2018 - 10:36 AM
This has been done a few times and work but like others have said, you'd be money ahead to find a 600 series Case. They were built with loaders already attached. The 448 frame is heavy for most GT duties but not really FEL work. The stock pump is plenty big for a loader. I use a Case pump mounted to the front of my 1655 to run the loader. It's even the Case pump mount since Case mounted the pumps to the Pto side of the engine. As for capacity, I'm only using about 40%. Case pumps are capable of 2200 psi at 12gpm+/-. My loader relief is set around 800psi.
  • KennyP and Firemang have said thanks
#7 Casinojim OFFLINE
Casinojim
  • 164 Thanks
  • 196 posts
Posted February 13, 2018 - 09:35 AM
Is this the one https://portland.cra...6480511285.html
#8 Firemang OFFLINE
Firemang
  • 187 Thanks
  • 197 posts
Posted February 26, 2018 - 06:52 PM
Yeah that’s the one.
#9 Firemang OFFLINE
Firemang
  • 187 Thanks
  • 197 posts
Posted February 26, 2018 - 06:53 PM
If anyone there has a 222 with a Kohler K301 in it, can you please tell me what rotation it is from the PTO side, looking for a replacement
#10 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted February 26, 2018 - 07:49 PM
Clockwise looking at flywheel, shaft counterclockwise.
#11 Firemang OFFLINE
Firemang
  • 187 Thanks
  • 197 posts
Posted February 28, 2018 - 02:39 AM
Well I wound up buying the skeleton tractor that CasinoJim put up a pic of. (Jim are you the Massey/Deere/Case guy in Grande Ronde I see putting up a lot of machines on Craigslist?) after doing some research the 448 is actually a 1974 446. I also bought a 222 the guy had that is complete minus a busted steering knuckle and a seized engine. Found out that one is a 1975. So the plan now is to rob what I can off the 222,get a replacement engine and start rehabbing and fabricating.....butttt....that's gonna be awhile. I'll get some pics on one of these days if ever stops raining
#12 Casinojim OFFLINE
Casinojim
  • 164 Thanks
  • 196 posts
Posted February 28, 2018 - 08:33 PM
that's me trying to fund this addiction my 646 needs new shoes Steve Johnson was telling he was getting ready to sale some case tractors if you need a Onan motor or parts let me know a friend he has a few:smilewink:
Edited by Casinojim, March 01, 2018 - 12:49 AM.
